1990 Whirlpool electric stove burner arching
abcomatic
Feb 16, 2006
2,139
Bradford, Illinois
HI all. The right front burner shorted out tonight while cooking dinner. The control knob would only work on high now. What could be the trouble and the fix? Thanks, Gary
The short welded the contacts in the switch so it can't cycle the heat off an on anymore.  The fix is a new surface unit and a new switch. Merry F**king Christmas from your range. Was it your only 8" element? If so, pull out an electric skillet.
Tanks Turbo. I called the repair man and he is out on house calls. He'll get back with me. It's nice to still have a "mom and pop" appliance store that has been in business from the 1950's. No big box stores for me. Gary
Hi Gary, exactly what happened ?, if the element shorted out it usually will not work at all any longer, if the infinite switch failed it would not work at all or it could have a welded contact and would only work on hi no matter where you set it.
Where did you see arcing ? at the plug-in contacts or on the element it self ?
John L.
Hi Gary, Try reversing the bad element with another one from your range to see if the infinite control switch still functions properly, if so just buy a new element.
When testing the infinite control switch of an electric range always try the lowest heat first and see if it works without getting really hot, if the ICS is stuck on hi you will need to replace it.
John L
Couple of thoughts
The advice above is all good. I've had a few other things happen with Whirlpool stuff through the years, too. If swapping the burner/switch doesn't fix it, it might be one of these:
1) I've frequently seen the replacement top burner receptacle kits fail. Some of them aren't the same quality as the factory originals. 1990 was a long time back, you might just lift the top and make sure that's not a contributor to the problem.  I'm linking to the Whirlpool approved receptacle. You can get the burner and infinite switch at that site, too. A tiny bit more expensive than the Walmart stuff, but genuine FSP is always better. Oh, TheHomeDepot carries them, too.
2) There's no correlation between one infinite switch or burner or receptacle failing and others failing. We've got a 1956/7 Westinghouse Rainbow Range which has had two Corox units fail in the past 60 years - neither of which were the ones most commonly used. The only infinite switch to fail was for the speedy unit, and it's still in the GE catalog. Deep irony there, somewhere....
So - if you're otherwise happy with this stove - it's worth fixing. I'm not a Whirlpool fan, but their ranges are quite good.
http://https//www.applianceparts.com/PartDetail/Element-Receptacle-And-Wire-Kit/330031/3374
HI all, Thanks all for your help. The switch went bad and so a new one is on order along with a couple of new 8 in elements. I told him to get genuine parts and not after market crap. Gary
Hi Gary, be sure to look very carefully at the male terminal ends on the old 8" elements, if they are [ even a little ] rusted pitted on the sides you must also replace the burner receptacles or the terminals on the new 8" elements will quickly fail.
There is nothing wrong with good generic parts for this type of repair, but there is some junk out there.
John L.
