cfz2882
got this washer today for $20 in "needs repair"condition-owner had replaced a bunch of parts(pump,several pc boards,inlet valve,flowmeter,boot)in attempt to correct a problem where washer would often stop mid cycle and set an error code-washer came with original parts that were replaced and examination of these found the original pump to be very badly worn and would have caused trouble...This washer has larger capacity than any of my other washers(heater too) so I will probably keep it for bulky loads once fixed
BTW,this is the model with the black control panel and door-matching dryer in good order is avalible for $150,so I'm thinking about buying the dryer to have matched set.Washer is made in Germany (and I presume basicly a WP Duet?) Is this a good washer(and dryer)and anything I should look out for with this machine?
