3 GM frigidaires home and running
akronman
Bronze Member
Jul 20, 2010
2,260
Akron/Cleveland Ohio
A Detroit gentleman posted a few weeks ago that his 1978 1-18 started to leak at age 34, he wasn't sure he could or wanted to fix it. I emailed him, made a deal, and got his MATCHED SET. He and his bride bought in May 78, he's done minor repairs and kept them in darn fine shape for 34 years.
Both are now running in my basement! WIB and DGCIB, Almond (couldn't quite be picky about that)
[this post was last edited: 8/15/2012-21:37]
dryer
Gas dryer, DGCIB, Serial begins in 8, all seems very accurate. He said he replaced the rollers about every 18 months???And the igniter once and the gas valve solenoids.  The 240 line above this dryer is for the Kenmore Galaxy next to it.
more
3 temps plus No Heat, and both timed and automatic dry cycles. I haven't looked at the schematic very well, but I'm assuming this is a standard heat versus timer deal on the automatic cycles, no moisture sensing. My one modern moisture sensing dryer doesn't do a damn bit better than the heat v. timer ones, frankly.
The "PRESS GUARD" operates when PermPress heat is chosen, whereas for Delicate and Regular, it just rings a loud buzzer and shuts off.
Extras tips
The Detroit fellow kept everything, and was very helpful and polite. His wife said these machines haven't been apart in 34 years, I better install them next to each other. But all my drains and water are in the center of the basement, and the outside walls are best for dryer vents, so don't rat me out, they were too nice.
even more
I also have a 1975 model, not pictured here and currently needing work, but there's almost no changes, even the faux wood dashboard has the exact same tree rings! The 75 has a bed of nails filter, this 1978 has the strainer basket instead. Also the lid switch has moved from left edge to center from 75 to 78.  Both have exactly the same cycles and include a spray after the final rinse in at least PermPress and regular, why I'll never know. One difference, and the 78 does claim Energy Saving Settings, this model gives a cold-cold choice, whereas the 75 did not. Which I'll never use.
I know I always fall for my "newest" acquisition, but these 1-18's are fantastic washers, excellent rinsing, great turnover even on slow, and they handle large oversize loads. When I started this ridiculous hobby, one of the first machines I wanted was Mom's long lost 73 GM Frigidaire, and now I own 2 replicas!  My 75 nodel is tempermental and requires something erpaired every 3 months, so this one will be treated with extra gentle use and care.
Leak
Yes, still leaking, but it's only been downstairs since 6pm, 2 loads of clothes. routine 1-18 leak from the little plastic tray they came up with, not quite a cup of water per load, and all kept away from the mechanics.
I'll give it a week of work before deciding what to do for repairs.
lint screen in the door
I'll run all 3 machines for about 5-10 loads before tearing inside for clean and delint and lube,. all 3 were installed and running just before my purchase. My boyfriend tells me I'm nuts, but I notice he doesn't say it as loud when he throws his clothes down the laundry chute knowing he doesn't have to do another damn thing.
1962 DIA electric
The 62 dryer doesn't have a push to start button,but I got used to that lack on my Hamilton, oh well. This 62 model is very noticeably smaller inside than the 1-18, but still larger than my 1975 DE606. This DIA-62 has Hi and LO heat and none, (named Sturdy and Delicate) timed and AutoDry cycles, no drum light and no buzzer and no wrinkle prevention. But works well, quite hot on Hi
Mark congratulations.  You landed a special pair that aws lovingly cared for.  these will last a long time with proper attention.  The BF should appreciate the perk of having a man in his life who will get his laundry done and have fun while doing it.
Nice set!
What's the model of your 1975 washer? I didn't think there were still models without cold wash / cold rinse then. About the final spray rinse during the final spin, I think is cold in some cycles even if the rinse water is warm to cool down the clothes. My 1-18 washer has a "fabrics" selector instead of temp/speed selector but I think it does that on the regular cycle with the "fabrics" selector to "delicate", on "premanant press" the rinse water can't be warm with "fabrics" on delicate...
 I'd be curious to see a closer shot at your 1-18 dryer's timer dial. I think this model has a "press saver" feature that's turned on when you select "knits & permanent press" or something like that. Does the buzzer sounds a few times while in the "press saver" mode?
On my 1977 DECI dryer, the press saver is turned off by a separate control which can also turn off the buzzer (good thing!). And I find the buzzer a bit annoying on this model so I usually turn it off! The last Elite models had an adjustable volume for the buzzer like some Whirlpool models. I think it wouldn't have been a luxury to add that on Frigidaire 1-18 dryers before 1979 as their buzzer is very loud and it doesn't stop after just a few seconds! On the Press Saver mode, it's even more annoying at it comes on at a few occasions!
[this post was last edited: 8/15/2012-23:50]
comparisons
1975 #WCD doesn't say Energy Saving Options on the console, doesn't have ColdCold, here's a pic. Also doesn't have a water level diagram of the agitator on the level switch. Other than that, exact same controls and cycles.
dryer
I've only done one load of clothes, but the owner's manual says it goes into Press Saver only if the Knit-PP heat is chosen on the Automatic cycle. 1978 DGCIB. I know the upper models had on or off buzzer. This one has no choices and is an aggravating long loud buzz.
Hello Phil
Your set, with the console lights, is TOL or next to it. I know there's been a thread here about a rare all pushbutton model ELITE, I think it was not offered every year. So yours are the most common TOL models, both my 75 and new 78 are the dead center of the line up. On a variety of other washers---Maytag and WP come to mind, I'd really like an extra rinse option. But the 1-18's do an excellent spray rinse that works well for me, better than many other machines I use.
Everything you said about the buzzer is right, I think I'd prefer wrinkles to hearing it. All it takes is neutering the wires.
Aferim!
Very nice. I love these machines.
I thought Frigidaire deserved big kudos from the ratings magazines in the early Seventies when they overhauled their designs, but I guess GM didn't have enough baksheesh at that time to  kick in to their hoppers.
In the history of US home appliances that I am aware of, I've never seen a company respond so proactively to criticisms as did Frigidaire. Although I have to say I think the rollermatics were wonderful; I think they were a little too retro for the times that they were slammed.
Awesome machines! I have always wanted to own ANY Frigidaire washer from the 60's or 70's but so far I have not been lucky in finding one....The 62 dryer is AWESOME! The washer gods have definitely smiled down on you! You have a nice collection!
Ken, your illustrations are awesome! I don't know how you achieve that but they are really nice!
Mark,
Frigidaire downgraded it's model lines at the end of the seventies and model numbers used in the late seventies are quite confusing! Not speaking about the 3 other "parallel" series which had about the same features as the MOL models of the regular line: the Crown (with control panel design very similar to the ones of the regular series with woodgrain/black panels but the black parts being replaced by silver trim and the addition of window lids), the Custom (with different-looking controls and more woodgrain/ less black trim than the regular models) or WS series (with another different design of brown<span style="font-size: small;">-(not woodgrain!)</span>/silver panels and window lids like the Crown).
So about the regular series (with the woodgrain/large area of black controls from 1975-79):
The 3speed WCI was discontinued at the end of 1976 calendar year and replaced by the WIC and WIC-A. The WIC was exactly the same as the previous WCI but the lid switch was moved from the hinge to above the (still bed of nails) lint filter. I think the WIC was discontinued soon after it's introduction and the WIC-A with the same features less the 3 speed motor replaced it.
The 1978 documentation I have recently downloaded from this site doesn't mention your exact model  but 4 models for 1978, the WD-A 16lbs model, the WC which has the same features as your WIB and the later (1979) WIG, the WID which has a "fabrics" selector just like the previous WIA and like the later WCIB and (1979)WCIG and the WIC-A which is almost unchanged from 1977 (changes during production were I think, the switch from shaded to non shaded colors and maybe the lint and filter and fabric softener dispenser styles).  Somewhere between 1978 and 1979, they replaced the WIC-A by the Elite, the WID was renamed WCIB and WCIG and the WC was renamed WIB and WIG.  So it seems they changed model numbers more than once a year but changes between some models are hard to tell. Custom Deluxe models became Imperials, Imperial models became Custom Imperials and Custom Imperials became Elite...
I thought the 1962 Custom Imperal's were the best looking washers ever made. What I wouldn't give for a set of them today.
My parents had a set in their laundry room and used the lights on the washer/dryer as night lights for the room. And they really lit the room up nicely. You didn't have to have the washer or dryer on to use them. In their home the laundry room was the rear entrance to the house.
Congrats
Great new machines you got Mark. Sounds like the 1-18 needs a new tub seal or the base plate gasket needs to be replaced and resealed.
Ask me how I know!
Love the matched set and the clamshell dryer. Very nice!
Patrick
