This was a new one on me.
Friends built a house in the country about 15 years ago. It has a septic tank and a drainfield. Recently their youngest son (a second grader) ran inside announcing he'd discovered a "new spring." You guessed it -- it was a clogged sewer line that had popped its cork, so to speak.
The guy who came to pump out the septic tank told them there was nothing wrong with the tank, but showed them a filter in the line ahead of the tank that was completely clogged with a white substance he identified as powdered laundry detergent. He said that using a HE machine (which they've had since 2010) made it worse. He advised them to use only liquids and the problem would never recur.
I kept my mouth shut, but have grave doubts about all this. True, they've been heavy users of Tide HE powder, which is probably loaded with washing soda and zeolites, and they live in an area with fairly hard water (central Kentucky) but it's hard to believe that laundry detergent/minerals alone would cause a clog, when you consider all the other stuff going through there.
Also, the sewer guy also claimed that using a water hog washer would help, but that takes MORE detergent, not less. So wouldn't that cause more clogging? This implies he thinks its a flow problem, too.
Anyway, they've switched from Tide HE to (wait for it) XTRA liquid and homemade washing soda/borax/soap! Something tells me this isn't going to be any better on their septic lines, AND their clothes will not be getting too clean, either...
