Hi there! Just broke the blower belt on the old gal, so I figured it was time to tear down and clean/lube everything. Question: what do you use to lube the rear drum bearing? This is the newer configuration that does not have a hole on the shaft. Should I use grease, oil, and what type? Also curious what to lube the tensioner pulley with? Are these oilite bearings from the factory? Thank you all for any help you can provide.
