'66 westy "jet set"on the bench...
cfz2882
Feb 9, 2010
2,725
Belle Fourche,SD
got my Westinghouse "jet set" B/W TV out of storage and on the workbench:got it about 16 years ago in inop condition-tried it after getting it and it did nothing-today checked for a circuit at cord and there was 6 ohms and both fuses intact,so might give it another try after a gentle power up on the variac or series bulb after a few checks have been done :).Set,all solid state except HV rectifier and PX,has a dark-tinted glass panel over the PX,so just a black rectangle visable when set off-mid-'60s chic :).Looks same as '65 version,but date codes of 6528-6601 found on internal components.Looks like Westinghouse TVs had a fairly short run as I have only seen westy TVs from around mid-1950s~1970 era.
It sounds like one of the "Instant On" sets Westinghouse was making in the late '60s.  Our neighbors had a portable on a rolling TV stand.
The folks once had a Truetone, Western Auto TV.  I remember Mom noticing the glow in the back one night, when it was off.  I think she was unplugging because of a lightning storm.
I have heard some recon "instant on" feature actually helped preserve the tubes since internal parts not moving around from thermal expansion during warmup-others have thought tubes get "used up" faster always heated :)In the jet set,found another fuse-this one blown-it is a weird short length "bayonette" type-clipped in a 100w bulb instead,and set lit up and had sound,but HV not working-seems that section pulling excess current-most parts have passed basic checks,but have not tested HO transistor and there is a sketchy looking area on the flyback,so I hope that is ok...
bad flyback
so it will be a fridgetop decoration for a while before being placed back into storage-meanwhile will keep an eye out for replacement flyback possibilities...
wondering if flyback a weakness on these
all other mid 1960s jet sets I have seen online have all been inop-and mine a little"shopworn"-sloppy repair solder jobs,mis matched screws,'69 dated HOT, etc...so these might not have been all that reliable...next might move a '61 Magnavox onto the bench-this one actually still works,but corona can be heard at times and no doubt some caps are quite stale :)another is a 1960 portable(forget the brand,might be Admiral)A series string set,has two white ceramic plug in silicon diodes instead of the selenium usual at the time.
Too bad on the flyback-If the set is that precious you could see if replacements are available.Otherwise try to get a working transformer from another junk set.Last resort you could put a new chassis and screen in the cabinet-yes,its cheating-but sometimes a good alternative than letting a good cabinet go to waste.
I have a box of 10 or 12 salvaged flybacks I mostly saved for plasma balls and other "Tesla"devices-if I find where I have those stashed,will see if any compatable :)
