Gas tumble dryers never caught on in the UK, they were expensive to buy, and expensive to install, as it needed a gas safe/corgi gas engineer to run the pipe and connect it up, plus they should have an annual gas safety check. And of course you'd need a vent hole knocked through the wall, which can't be too close to an opening window, whereas a conventional condenser dryer is cheap to buy, can go anywhere and just needs plugging in.
There were also very few shop selling them them and never much choice. The only remaining manufacturer in the UK stopped selling them a few years ago.
Then there is the economy 7 electricity tariff, which offers cheap off-peak electricity overnight (and used to be much cheaper than standard rate than it is now).
I think when I looked into it, which was before heat pump dryers were available, I worked out that a conventional (electrically heated) condenser, or vented dryer wouldn't cost much more to run on cheap rate E7 overnight than a gas dryer. But, if you ran the dryer during the day, a gas one would be around a third the running cost.
I think in the UK, it makes little sense to buy anything but a heat pump dryer now, unless you need to have it in an unheated outbuilding as they don't work well at low temperatures.
