A/C gone bad
I'm quite happy with my variable speed dual stage 98% efficient gas furnace.  Initially I had it set up for CAC ( continuous air circulation...) and it kept the entire house at the same comfortable temp, no hot or cool spots. Plus, I LIKE air movement, a home without feel stagnant to me. I updated my thermostat a few years ago and it offers a circulate mode - every 15-20 minute it turns on the low speed blower for a minute or two and moves the air around.  It works almost as well as the CAC, but at a lower electric cost, so I'm ok with that. I also keep the humidity around 50%, so I'm comfortable at a lower temp. The humidifier track the outdoor temp and adjusts accordingly.
We all have our preferences - baseboard heat would rank about the same as oil heat, maybe lower.
Noise to sleep..
<span style="font-family: helvetica;">I like it quiet and my husband likes some noise.  We tried the thunderstorm sounds on Alexa and it drove me crazy because if I was awake it would play the same ones over and over.  We have a ceiling fan but its quiet and to get it to make any noise it has to be on pretty high and I don't like that blowing on me at night.   Our HVAC is so quiet you don't hear it running so we bought one of those small Oreck air purifier thingies and that's enough for him.  We run it on medium instead of silent.  It took me a couple of nights to get used to the sound but now I don't even hear it anymore and we get clean air.  LOL.  Two birds, one stone.</span>
We've been here before
Heat pumps are not more noisy than a furnace in regards to your actual noise in you home.
Any resistive heat has a COP of 1, even the worst heat pump has a COP of 2.5.
We get you don't like it.
Stop being so aggressive about it.
And don't twist the facts.
Right now it's 30F outside. My all electric heat pump is set at 64F... I know it has to be very inefficient when we have super cold weather because the heat strips kick in a lot.
My friend across town that I used to work with keeps her AC at 78 in the summer. I was at her house visiting one hot day, I was miserable...the maximum I can go on my AC is 73F in the summer during the day - but at night bump it down to 70F
I dread when the day comes having to deal with getting a new system because there's so many factors to deal with.
Henrik
He isn't mistaken when stating that a heat pump makes more noise. It's not a lot of noise, but they do make more noise and they also make some other weird clicking noises that it doesn't make when cooling.
I had a house with a heat pump and the heat it made wasn't a warm or hot heat thus it took longer to heat the home.
That system was ripped out and I put in a gas furnace. That was 2002.
Once again, not how that works
If it has the same heat output as the gas furnace, it won't take longer to heat the house.
The air temp dosen't play a role in getting the room to temp quicker.
If it took longer the system was sized smaller.
And again, plain functionally, a heat pump will produce basically the exact same noise in cooling as in heating mode and thus the same as any AC.
There isn't really a thing that could make any appreciable difference in noise.
#50
Yeah, I'd never rely on a heat pump alone. Although I think a few members here have been rather surprised at how low temps go before backup heat is needed. Can't remember who, though.
And yes, insulation first and foremost. And I HATE cold floors so my knee-jerk response is always "Insulate the basement!" If I had my way any place I lived would have radiant heat in the floors....... Maybe I'll get that...... One day.......
#59
I've never lived in a place with oil fired warm air. My grandparents had oil fired steam and there was NEVER any smell of oil... EVER... unless the oil filter in the feed line was getting changed. One house I bought in the 90's had oil fired steam and there was a smell. I called the oil company and the CSR proceeded to lecture me about how I "didn't understand" about oil heat and it ALWAYS had a smell. I thanked her for her time and told her I was switching to gas :-) No problem....
Baseboard: When there's enough of it I like it. It's very even.... no drafts and no cold spots. Unfortunately, most of my experience has been when a 4 foot radiator was taken out and 4 feet of baseboard put in. As you can imagine, that didn't work very well when temps dropped. I've tried to explain to people that it doesn't work that way and they usually tell me that it does (while we're shivering) and that it saves money.
Years ago I lived in an apartment that had 2'x2'x4" semi-recessed radiators. Shortly before I moved in they were ripped out and replaced by 2 feet of baseboard within the enclosure. I was kind of friendly with one of the maintenance guys and asked him about it. Some company had convinced the co-op board that this would save money. he told me that the building & grounds head honcho tried to explain the board that the sales line was physically impossible, but he was ignored. I was told that with baseboard they had to keep the water about 20F hotter than they did with the radiators. And my place was still cold when it went below 25F.
Having lived many years in a house with hot water (hydronic) baseboard heat, I can say it works very well. The first boiler was oil-fired, and then an electric boiler was installed in 1974. The heat was even, with no drafts. The heating  system had to be removed due to the major renovation, as did the "Space-Pak" air conditioning system. I had a ducted forced air hvac system installed, that is supposed to have a heat pump, though that part was never installed due  to various factors. It has electric resistance elements, but I don't use it as I'm only living in part of the house right now. I looked into geothermal, but got estimates of over $30,000., so that was out. If I had it to do over, I think I'd put in a new hydronic system, using an air to water heat pump, that could also supply an air handler for cooling. They have cold-climate models that can heat even well below zero. Guess that's not likely to happen unless a money tree comes up in my yard.
Exactly right about hydronic...I had a tract ranch house in suburban Chicago which was built with gas forced hot air, and the first owner in roughly 1962 ripped it out and put in gas baseboard hydronic...chef's kiss. Was a wonderful system. The utility closet was in the bathroom (louvered doors got rid of all bathroom odors--woot) and except for the woosh at the ignition of the burner on the boiler the circulating pump was so low-toned that you were entirely unaware the heat was on...it was entirely inaudible. Big contrast from the wooshing of the forced air furnaces in the middle of the house.
Air-conditioning was provided by a 220v window unit in the living room--as long as you ran that during the summer as a central a/c unit (i.e. cycling continuously) the house was plenty cool (with perhaps a box fan at the end of the hall pulling the cool air into the ends of the bedrooms).
Our 1958 built house is still using its original gas boiler with baseboard radiators. I really like it over forced air because the heat is even and it's fairly quiet although not as quiet as before I had the pump replaced two years ago. I keep meaning to go down there and jiggle around with it because the noise itself isn't the pump, it's harmonics on the water pipes. There's not a lot of maintenance other than adding some water very occasionally and then maybe having to bleed some air out of couple of the radiators every year or two.. I just did one in the small upstairs bathroom yesterday. Takes only a couple of minutes. We keep the house at about 72-73 all winter and I've compared our gas bill with a few of my neighbors who have gas forced air, and surprisingly our gas bill is less than theirs, our house is slightly bigger too with a heated two car garage.
The only thing I don't like about hydronic heating is not having central air and relying on the mini split. My new mini split from last year is also a heat pump though I've only tried it to see if it works and it does. It's sort of like an emergency backup I guess in case something went wrong with the boiler we'd have a little bit of heat.
Hydro radiant heat
While it has been less of a possibility up until now, at least over here, the most recent generation of heat pump systems can reach high enough temperatures to run even pretty old radiator systems.
It's not as efficient as underfloor heating (which is still the best thing IMO) in combination with an x-to-water heat pump, but still more efficient than straight up electric heat and potential zero emissions.
Heck, our oil boiler system back home barely reaches 120F with a combination of under floor heating and radiators.
That system uses an adaptive heating curve calculation based on a set room temp and an outside temp sensor.
One thing that apparently is kind of different from the US to us over here is that at least for detached or semi detached homes, usually, heating and hot water are handled by a single system.
Usually you have a hot water tank and your heating circuit both connected to the same heat source through a set of 3 way valves or similar.
So your burner (or heat exchanger) is used for heating water and your heating circuit.
I guess that's mainly because forced air systems are basically unheard of for heating over here in such installations.
Basically everything is water based and either radiators or in more recent installations underfloor or similar.
In such installations, switching over to an heat pump dosen't change your heating much.
Biggest problem is that some kind of radiators need to high system temps to make heat pumps useable.
Even if your radiators tolerate the lower temps, the higher the temps needed the lower the efficiency gets.
In a perfect world, your heat pump can satisfy heating demand with a 110F system temp and with under floor heating, that is basically always a given.
And since we don't need 140F water out of the tap for our appliances, 130F tank temps are still good enough.
I guess in the US it really depends on what you already have.
If you have forced air, a heat pump just is the way to go.
If you have radiators, it depends on your radiators.
Most cost effective yet environmentally conscious option would probably be an x-to-water heat pump and replacing your radiators with more up to date low temp ones.
Not sure if baseboard radiatiors can be had for lower operating temps though.
If you have electric baseboards fitted fitting anything else would be a lot of renovating work.
If you however have some kind of AC fitted aswell I don't see a reason to supplement the "wasteful" resistive system with a split heat pump.
Done in 4 hrs, 9a to 1p.
1 - 5 = old.
6 - 14 = new.  11 & 12 east --> west view from stairs side.  13 west --> east view from other side (must climb over).
They forgot to bring the 4" filter module that wasn't on the quote but I requested and he agreed to include.  To be added in a few days.
That's all I have.  No pics of the heat strips before installation.
Best I could get out of the local contractors, who insist that the replacement match the original 5 tons, which may be reasonable on point of the ductwork being designed for it, is a 2-stage which will run at 70% capacity (3.5 tons) on low.
Yay New Train Heat-Pump
Looks Good,
Question Glenn how is an A coil mounted in a horizontal air handler, I have always seen A coils in up-flow or down-flow air handlers.
It also looks like you might want to put more insulation in the attic and maybe even some on the plenum attached to the air-handler. I think that almost everywhere you should have at least R30 in attics.
John L.
John, the A-coil and air handler are convertible to upflow, downflow, horizontal left flow, or horizontal right flow.
I had a media air cleaner (Honeywell F100F2025, 20x25x4) added (installed today) so I can now see the coil through the filter slot.
Current outdoor is 32°F to 35°F depending on the reference.  Misty rain.  Setpoint 68°F maintaining on low stage.  Cycling earlier in the day, increasing to continuously running now for probably more than 2 hrs.
Thermostat configured at "comfort" to hold temp within 1°F of the setpoint using low & high compressor stages per algorithms that monitor the indoor temp curve.  It has not yet engaged high stage AFAIK for any heating since the 1/4/22 install date.  Be interesting to see if it'll upstage soon.
Auxiliary staging choices of
   A) "comfort" on aformentioned algorithms
   B) specific °F setpoint droop in 0.5°F steps
   C) specific upstage run-time (30, 45, 60, 75, 90 mins -- 2, 3, 4, 5, 6, 8, 10, 12, 14, 16 hrs)
   D) combination of B and C.
Currently set at 3°F droop, which will present obvious indication when it's needed, and whether adjustment of the setting is needed.
Predicted low of 24°F tomorrow morn.
What would you do?
I removed the service panel on the compressor unit several days ago for a look-see at what components are in there.  Found the tech sheets, scanned them to .pdfs for future reference, put them back into the storage envelope.
I noticed the red light on the EEV (electronic expansion valve) board flashing a sequence, so looked for the code on the tech sheet.
Code 7 -- Valve is responding but system is not performing properly (Low charge or restriction).
Codes 1 to 5 reset on a power cycle.  Codes 7 to 10 require a specific reset sequence so may be flashing history instead of an active code.  I thought maybe the code triggered during installation on the initial run while they got the refrigerant charge settled so I enacted the reset procedure, it stopped flashing.
Checked again a few days later after the system had run a few cycles, Code 7 is flashing again.
Should I bring it to the contractor's attention (without mentioning that I had done the reset)?  A homeowner isn't supposed to be poking into the mechanism and I'm leery of presenting as a "problem customer" two months into the installation ... but it needs to be checked if there is a problem.
Flashing red fault light
Hi Glenn, I would definitely call the company that installed the system, this is your system you’re allowed to take it apart examine it all you like the only way they can void warranties is if you actually caused some damage.
Just explain that you were inspecting your nice new system when you opened up the panel you saw the flashing red light you looked it up and found that it may be a restriction or low charge and ask that have them check it out.
John L
Follow-up:  There was a "tiny" leak at one of the refrigerant charging ports.  Enough had leaked out to trigger the fault.  Fortunate that I looked there and caught the code.  I am expecting it to run for long periods on low speed as summer weather progresses so wouldn't have noticed a performance impact until it couldn't keep up on high speed, or safety sensors shut it down completely.
I would consider that a fairly large leak if enough refrigerant leaked out in a 3 month timeframe to trigger a low pressure switch code. I’m glad you called and got it taken care of.
I checked this afternoon, it's flashing the F7 code again, or still.  I didn't check immediately after the repair two months ago so I suppose it's possible they didn't clear it then.  I cleared it now to watch for recurrence ...
