48bencix
1946 Ranch House
I moved here in 1990 into a 1946 Ranch with 1960 bedroom and family room additions. One window unit in the family room really did not cool the whole house. I designed and installed a new system with the gas furnace outside the slab on grade family room and ducts into the attic for the rest of the house. (Built a small outside enclosure for the unit) Components such as condensing units were available at the time for a homeowner, now only to contractors. I hired an HVAC contractor to connect the condensing unit and add any charge required.
Fast forward to 2017 and I decided to replace the furnace and condensing unit. Had a contractor install Trane units and permit required testing of all existing ductwork. Leakage was less than allowed for new ducts, so my original ducts system was passed. Old SEER was 11 new is 14 with 80 AFUE for the furnace. Better efficiency but not really high efficiency as I believe this will be more reliable. Contractor provided a 10 year parts and labor warranty. I serviced the old units myself mainly changing the furnace igniters and run capacitors in the condensing unit. With the ranch style no need for zoning. We did insulate the walls (no existing wall insulation) and added attic insulation.
