A/C gone bad
<blockquote>... but am struggling to figure out how this could have been an innocent mistake.</blockquote> What's stated in your equipment quote?  Was there any direct discussion of a two-stage thermostat?  Any discussion or mention by either you or the installer of keeping the original thermostat?  A single-stage thermostat sometimes is used with a two-stage system for "reasons" ... such as keeping the job to a price-point or avoiding the need to run additional thermostat wiring if that presents some challenge.  The system will work although not to the best design-performance.
The T4 line does have a model that's 1C-2H for one-stage/speed heat pumps with one-stage of auxiliary/backup heat, but your stated compressor model 4A7A7036A1000 is a cool-only unit ... maybe the dealer's installer team overlooked that?  Do you have gas for heating?
John ,
I would call them out  as soon as possible. I would be kinda pissed if in your contract that you paid for , it says
American standard  Model # , Furnace  , with T-stat .  My contract said the model number of each item ,T-stat also both of them.
I have Two  2 stage   American Standard heat pumps upstairs and downstairs , they run all the time on low
one is a twin compressor and the other is a two stage scroll .
 If its a reputable company they should fix it no problems. I had a 10 year parts and labor warranty with mine when it was installed in 2007/08 .
Don't pay a dime don't let them try to charge you for the service call to come out and fix there mistake
and sometimes they would try to charge me. Hoping I would be stupid enough to pay them.
Hi Glenn, yes, I have a two-stage modulating gas furnace also. There was no discussion of keeping the old thermostat since it was an old round Honeywell with a mercury switch and obviously unsuitable.
Thanks for the advice, Wes.
I talked to the owner's son who seemed surprised that I had a problem and insisted that the unit(s) would work just fine in both stages with the existing thermostat, but he said he'd investigate and get back to me. He seems to think I would need a VERY smart thermostat like an Ecobee or Nest, which I'm not thrilled about based on what I've read. I don't think I need an adaptive thermostat, and I don't want everything being reported back to Google, anyway.
We'll see.
There surely are other workable thermostats than Nest and Ecobee.  They're trying to upsell you, or they don't know what all is on the market, OR they may be tied to only what a particular supplier carries.
The model I have should work nicely, I don't know the cost of it (search it at online sources), the bill didn't itemize individual component prices.  It has WiFi but connection is *not* required for it to work properly, nor is an outdoor temp sensor (which I don't have).  It does pick up an outdoor temp via WiFi (based on an unstated reference per the ZIP code if that info is entered) but again, it *does not* require an outdoor temp reference for staging control.
The glitch may be if your system is a high-tech communicating control system that requires specific thermostats to interface properly, but that seems unlikely.
My Honeywell has dual stage capability, no need for a Nest or such. Depending on your provider my Utility company is often offering free t'stats if they are programmable - no need to program them.
Thermostats
I have an Emerson 1F95-1277 that's been great. It's called "Big Blue Universal 3/2". It can work with many different HVAC configurations. It has 27 different settings, you go thru it all in the installer/config menu. It has a nice blue display, very easy to read, no WiFi or other nonsense. You can even program in reminders to change air filters. I set up programs for the winter, but in the summer I prefer to use it manually, adjusting temp settings for how I want the house cooled.
It's somewhat pricey, around $180. Just my review and recommendation.
https://climate.emerson.com/en-us/shop/1/white-rodgers-sku-01f95-1277
He is lying John , I am sorry to say any two stage American Standard Air/ heat pump will  need the
two stage T-Stat. That switch uncovers the ports in the scroll which makes it run at 67%  and then reduces the air flow .
The let me talk to Dad is basically let me blow you off or screw you talk . Not even a hug after.
I would call and keep calling and then I would drive up there and demand it.
Those T-stats are not cheap , I have never seen a contractor change out a system and not put in there own unless it was requested.
I would drive them NUTS ...     The Air will work but what was the point with installing a dual stage if you cant use it. It's like buying a car and they did not give you the keys .
Electric usage for Aug 2021 when the old system went kablooey was 2,488 kWh.
Aug 2022 is 1,381 kWh.  The setpoint has been a raised a bit for several couple-days periods when I've been out-of-the-house for attending dad's extended hospital stay, but the higher setpoint is what I'd been running as normal a year ago so the effect isn't much.
Electric rate is up a bit from last year but the bill is still $100.76 less than Aug 2021 and there's a (biennial) capital credit refund applied atop that.  Yay!
Latest arctic blast.  Outdoor temp is currently 25°F, predicted low of 20°F or 19°F.  The Trane XR17 heat pump is maintaining the indoor setpoint of 69°F, cycling between low & high stage without triggering the auxiliary.  Wall thermometer in a bedroom reads 69.7°F.  I have the thermostat programmed for a 3°F droop on auxiliary to provide an obvious indication if it's needed.  Stage 2 is set for "comfort" vs. a °F-droop or time-period.  And "finish on high stage" = no, which means it'll drop back to low stage when the room temp is within the "comfort" algorithm's satisfaction (instead of staying on high stage to attain the setpoint and shutting off), which makes for a more steady room temp curve.
Also, one of the auxiliary breakers (purposely) is turned off.
19.7°F on the patio.  17.7°F at someone's personal weather station a bit north outside town linked on WeatherUnderground, 16.9°F on one at south end of town, 17.4°F in town, regional airport several miles east says N/A.
Bedroom of reference 69.6°F.
