Need not necessarily be a "high" pH; just alkaline. To a point stronger is better that is why washing soda is a better cleaner than borax; but the reaction is same.
It all comes down to something we all learned in chemistry classes while at school, saponification.
https://en.wikipedia.org/wiki/Saponification
Base substances react with fats or oils to become "soap". For cleaning or laundry purposes we use that process to turn fats/oils on surfaces or textiles into a soap that then can be washed away. When you pour lye based drain cleaner down drains it reacts with fats/oils to become "soap" that can be cleared away because the clog is now dissolved. https://en.wikipedia.org/wiki/Ester#Addition_of_nucleophiles_at_carbonyl
High pH substances are or were a good choice because they are cheap and performed reliably at their task. But for laundry use they also bring a host of other issues.
Higher pH used to "break" or for detergency means more rinsing is required including a sour bath to restore final pH levels that won't irritate skin.
Repeated high pH washing also can take a toll on certain fabrics especially those of cotton or linen. Just one wash will likely destroy silk or wool fabrics.
If you've ever used a powdered detergent, especially the more BOL bargain brands that left your clothing hard and scratchy; likely culprit was excessive washing soda, caustic soda and other high alkaline substances.
In fact you can make a pretty good "detergent" using nothing more than some sort of surfactant and sodium metasilicate alone or blended with washing soda or another alkaline substance. For years laundries in UK and Europe did just that by using soap and metasilicate along with hot to boiling water. The other benefit of this was that the high pH also destroyed protein including blood stains.
Persil soap powder was nothing more than PERborate, SILicate and soap. Hence the name PER-SIL.
