As Jeff asked for here is the "HUGE Load of Colors" Cycle. This cycle is meant for washing about 125-150% of the capacity of the tub, because of the recirculation keeping the water level at it's highest it works extremely well and raises the usable capacity of this washer greatly. Again in the paraens are the following parameters that are passed to the washer <br
Motor = Agitatio
Solenoid = Tub Brake Released/Tub Coas
Motor + Solenoid = Spi
DivCab = Cabinet Water Diverte
DivJet = Jet Circle Spray Water Diverte
DevDet = Detergent Dispenser Water Diverte
Heat = Water Heate
RPump = Recirculation Pum
DPump = Drain Pum
Hot = Hot Fil
Warm = Warm Fil
Cold = Cold Fil <br
When you are reading the "Four Minutes of Magic" my pre-wash, see the footnote at the bottom for one important explanation <br
<font color=green>Call CreateCycle<font color=blue>("Function Name", "Operation Name", Time to run in seconds, Components Energized)<font color=black <br
Public Sub ButtonHUGE_Load_of_Colors_Click(
SuperUnimatic.Caption = "Super Unimatic - Cycle Selected: HUGE Load of Colors"
<font color=green>Call CreateCycle<font color=blue>("Hot Water Line Flush", "Line Flush", 30, Hot + DPump + DivCab
<font color=green>Call CreateCycle<font color=blue>("Wait", "Gently Engage Spin Solenoid", 1, Solenoid
<font color=green>Call CreateCycle<font color=blue>("Spin", "Rotate Wash Tub", 5, Motor + Solenoid
<font color=green>Call CreateCycle<font color=blue>("Fill", "1 Gallon Fill", 60, Warm + Solenoid + DivJet
<font color=green>Call CreateCycle<font color=blue>("Pre-Wash Gain Speed", "Gain Speed", 25, Motor + Solenoid + RPump
<font color=green>Call CreateCycle<font color=blue>("Four Minutes of Magic", "Concentrated Spray", 24, Solenoid + RPump)
<font color=green>Call CreateCycle<font color=blue>("Four Minutes of Magic", "Pulse Motor", 8, Solenoid + Motor + RPump)
<font color=green>Call CreateCycle<font color=blue>("Four Minutes of Magic", "Concentrated Spray", 22, Solenoid + RPump)
<font color=green>Call CreateCycle<font color=blue>("Four Minutes of Magic", "Pulse Motor", 7, Solenoid + Motor + RPump)
<font color=green>Call CreateCycle<font color=blue>("Four Minutes of Magic", "Concentrated Spray", 23, Solenoid + RPump)
<font color=green>Call CreateCycle<font color=blue>("Fill", "Clear Window", 5, Hot + Solenoid + DivCab
<font color=green>Call CreateCycle<font color=blue>("Fill", "Charge Tub", 30, RPump
<font color=green>Call CreateCycle<font color=blue>("Fill", "Cool Fill", 120, RPump + Warm + Cold + DivDet
<font color=green>Call CreateCycle<font color=blue>("Wash", "Start", 3, Motor
<font color=green>Call CreateCycle<font color=blue>("Wash", "Wash", 168, Motor + RPump
<font color=green>Call CreateCycle<font color=blue>("Wash", "Soak", 58, RPump
<font color=green>Call CreateCycle<font color=blue>("Water Drain", "Drain Cabinet", 10, DPump + Solenoid
<font color=green>Call CreateCycle<font color=blue>("Suds Kill Expel Wash Water", "Expel Wash Water from Tub", 10, DPump + Solenoid + Motor
<font color=green>Call CreateCycle<font color=blue>("Suds Kill", "Suds Kill Drain", 89, DPump
<font color=green>Call CreateCycle<font color=blue>("Wait", "Gently Engage Spin Solenoid", 1, Solenoid + DPump
<font color=green>Call CreateCycle<font color=blue>("Spin", "Wash Water Spin Off", 42, Motor + Solenoid + DPump
<font color=green>Call CreateCycle<font color=blue>("Spin", "Seven Second Spray Rinse", 7, Motor + Solenoid + Cold + DPump + DivJet
<font color=green>Call CreateCycle<font color=blue>("Spin", "Spin", 7, Motor + Solenoid + DPump
<font color=green>Call CreateCycle<font color=blue>("Spin", "Spin", 100, Motor + Solenoid + DPump
<font color=green>Call CreateCycle<font color=blue>("Fill", "Rinse Fill", 215, Cold + Warm + DPump + DivJet
<font color=green>Call CreateCycle<font color=blue>("Rinse", "Overflow Rinse", 60, Motor + Cold + DPump + DivJet
<font color=green>Call CreateCycle<font color=blue>("Rinse", "Softening Rinse", 70, Motor + DPump
<font color=green>Call CreateCycle<font color=blue>("Pause", "Pause", 1, 0
<font color=green>Call CreateCycle<font color=blue>("Spin", "Rinse Water Spin Off", 35, Motor + Solenoid
<font color=green>Call CreateCycle<font color=blue>("Imperial Rapidry", "Spin", 375, Motor + Solenoid
<font color=green>Call CreateCycle<font color=blue>("Drain", "Remove Ballast Water", 75, DPump
<font color=black>End Su <br
Estimated Cycle Time: 44:3 <br
*What is not obvious in the cycle list is that in the program code there is a special sub routine that watches out for the following condition <br
If <font color=Purple>Function Name = <font color=blue>"Four Minutes of Magic" <font color=black>and <font color=Purple>PressureSwitch = <font color=blue>Not Satisfied<font color=black> then continute to fill through the detegent dispenser until the pressure switch is satisified <br
and for the Suds Kill
If the first 9 characters of the <font color=Purple>Function Name = <font color=blue>"Suds Kill" <font color=black>and <font color=Purple>HE Detgergent Box = <font color=blue>Checked<font color=black> then skip this line and goto the next line. (This will Skip the two Suds Kill lines) <br
Clear as Mud LOL?
