A New Interface for the Super Unimatic 2.0
Agitation.!!!!
Morning Robert, Have you been sniffin to much DASH again...LOL, me thinks you should go for the finale and stick the Pigs (Wizard) Agi in, followed up by an Easy Spiralator......have fun. <br
AND,I hope not too many ASKO machines have been torn apart for parts,although a very good cause its just too much of a washer sin, that would get you 5 westy slantflonts and 2 rounds of the laundryroom, at the Confessional of the Washer Gods.. <br
Cheers, Mike
gregm has that Easy, Toggs, and somewhere in the Youtube wor
Robert, your experiment reminded me of the jetcone operation where the clothes rest for a bit on top
In the Frigidorge, they rested against the fins as if they were leaning against walls, cruising
Figured the gush wouldn't work, but one can always hope <br
Hello Patrick: Re: "Blasphemy" laughed but then realized the true superiority of the Frigidaire. It will wash anything, and it can wash WITH anything <br
A fire hydrant
a garbage can to
Gladys........ Obviously kidding but couldn't resis <br
OH NOOOOOOOOOOOOOOOOOO
<i>Inverted SS mixing bowl, drilled and secured, looking like a bell? </i <br
Hey not a bad idea Toggles, but a mixing bowl might be too deep, wouldn't you think? I believe those Easy Cups were more like deep saucers?
Hi Robert. I loved the Norgeidaire video. You are a genius to be able to fit the Norge agitator to the unimatic
mechanism <br <br
Ross
Hello Robert and mates
Trying to post on "Should I reduce?" but keep getting FORBIDDEN <br
Glitch or practical joke?
<i>Trying to post on "Should I reduce?" but keep getting FORBIDDEN. </i <br
I hope you are kidding because I do not have any time for technical issues today.
I just had a look on Live Earth and I noticed I saw men in white coats carrying straight jackets in the neighbourhood of some members... <br
Anyway Robert, thanks for that video, interesting that the Norge agitator fits in the Super Unimatic. BTW, personally I think it's a horrible sight that the Super Unimatic has a hole in the control panel where the timer used to be. Wouldn't it be nice to have some indicator lights in there <br
Louis
<i>I think it's a horrible sight that the Super Unimatic has a hole in the control panel where the timer used to be. Wouldn't it be nice to have some indicator lights in there? </i <br
But Louis, that's where the 3" Plasma TV is going to go so I can wash clothes and watch Bewitched at the same time.
Many may have thought it but none have yet said it.......
~I believe those Easy Cups were more like deep saucers <br
I thought you might need the width of such a bowl to get the required depth. <br <br
I get "forbidden" all the time. After two or three posts it'd come up. I'm thinkng it was a sign from the universe telling me (and me only! *WINK*) to "Stop posting, bitch."
Hello, Handsome
Not kidding--sent you an e-mail; please post; it's kinda funny. I try <br
Toggs, you get blocked because you're not helping Gary with his cash flow. I'm LAUGHING........... I'll try to find Gregm's Easy cup&saucer Youtube video and link it.
I love the custom enclosure for the interface, but
I'm going to add another vote for lights. I love lights, buttons, meters, gauges, indicators, etc. <br
Nixie tubes or Numitrons are very easy to drive. Green Eye tubes aren't difficult either. Neon lamps? Something <br
BTW, where'd you get the computer/relay interface boards? I built some devices many years back using similar boards from a company called, "Electronic Energy Controls." There's no end to the fun you can have with things like that <br
Keep up the good work -- it's people like you that make me feel normal <br <br
-kevin
<i>BTW, where'd you get the computer/relay interface boards? I built some devices many years back using similar boards from a company called, "Electronic Energy Controls." </i
Hi Kevin, the Parallel Port Realy Board comes as a kit that you solder to parts together from Carl's Electronics <br
Louis and others, as for fancy lights on the control panel, maybe some day, but for now I'm more interesting in having all the lights, dials, meters, gauges, indicators, etc. display on the computer screen. In future upgrades I want to add to the display the water temperature and rpm of the tub, and I'm sure I will think of lots of other things to add as time goes on. This washer will never be "Done" or "Completed", I hope to continue adding and upgrading new features until I'm too old to do the wash anymore LOL <br
As for the Software I wrote, here are some screen shots of a "Hot Suds White Towels" load, starting from when you first turn the washer on, thru the final spin. This all is about to change again as I'm going to do write software upgrade soon.
Chad my "Electric Blanket" cycle is a special super delicate cycle for washing my electric blanket. At night in the winter I love having the bedroom freezing and the electric blanket on high. Years ago I could wash and wash and wash electric blankets with no problem, but the blankets manufactured over the last 15 years or so have been of such poor quality that if I don't wash it extremely gently after one or two washings it's dead. Then I hang it over stairwell railing to dry <br
If you want to read the program code for the Electric Blanket cycle here it is, this way you can see exactly what the washer does for this cycle <br
The cycle creation section of the program is pretty easy to read, in between the parenthesis are the parameters that get passed to the washer (Function Name, Operation Name, Time to run in seconds, Components Energized). The time to run are estimated for the Fills. Each line in blue is a step for the washer to perform in that order <br
Motor=agitation, DivJet=Jet Circle Fill, DivDet=Detergent Dispenser, Solenoid=Spin Solenoid, DPump= Drain Pump, RPump=Recirculation Pump, Hot-Warm and Cold are obvious <br
Public Sub ButtonElectricBlanket_Click(
SuperUnimatic.Caption = "Super Unimatic - Cycle Selected: Electric Blanket&quot
Call CreateCycle<font color=Blue>("Wait", "Gently Engage Spin Solenoid", 1, Solenoid
<font color=green>Call CreateCycle<font color=Blue>("Spin", "Rotate Wash Tub", 5, Motor + Solenoid
<font color=green>Call CreateCycle<font color=Blue>("Fill", "1 Gallon Fill", 60, Warm + Solenoid + DivJet
<font color=green>Call CreateCycle<font color=Blue>("Fill", "2 Gallon Fill", 90, Warm + Solenoid + DivDet
<font color=green>Call CreateCycle<font color=Blue>("Pre-Wash Gain Speed", "Gain Speed", 35, Motor + Solenoid + RPump
<font color=green>Call CreateCycle<font color=Blue>("Pre-Wash", "Concentrated Spray", 60, Solenoid + RPump
<font color=green>Call CreateCycle<font color=Blue>("Fill", "Clear Window", 5, Solenoid + Warm + DivCab
<font color=green>Call CreateCycle<font color=Blue>("Fill", "Charge Tub", 30, RPump
<font color=green>Call CreateCycle<font color=Blue>("Metered Fill", "Warm Fill", 120, RPump + Warm + DivDet
<font color=green>Call CreateCycle<font color=Blue>("Wash", "Wash", 30, Motor + RPump
<font color=green>Call CreateCycle<font color=Blue>("Wash", "Soak", 120, RPump
<font color=green>Call CreateCycle<font color=Blue>("Wash", "Wash", 15, Motor + RPump
<font color=green>Call CreateCycle<font color=Blue>("Pause", "Pause", 1, 0
<font color=green>Call CreateCycle<font color=Blue>("Wait", "Gently Engage Spin Solenoid", 1, Solenoid + DPump
<font color=green>Call CreateCycle<font color=Blue>("Spin", "Wash Water Spin Off", 42, Motor + Solenoid + DPump
<font color=green>Call CreateCycle<font color=Blue>("Spin", "Spray Rinse", 30, Motor + Solenoid + Cold + DPump + DivJet
<font color=green>Call CreateCycle<font color=Blue>("Fill", "Rinse Fill", 230, Cold + Warm + DPump + DivJet
<font color=green>Call CreateCycle<font color=Blue>("Rinse", "Overflow Rinse", 30, Motor + Cold + DPump + DivJet
<font color=green>Call CreateCycle<font color=Blue>("Spin", "Rinse Water Spin Off", 35, Motor + Solenoid
<font color=green>Call CreateCycle<font color=Blue>("Spin", "Seven Second Spray Rinse", 7, Motor + Solenoid + Cold + DPump + DivJet
<font color=green>Call CreateCycle<font color=Blue>("Spin", "Spin", 7, Motor + Solenoid
<font color=green>Call CreateCycle<font color=Blue>("Imperial Rapidry", "Dry", 60, Motor + Solenoid
<font color=green>Call CreateCycle<font color=Blue>("Drain", "Remove Ballast Water", 75, DPump
<font color=black>End Su <br
Estimated Total Cycle Time: 21 minutes, 33 seconds.
