A parts unit for my LG.
maytagneptune
May 7, 2017
193
FireAlarmTechGuy4444 on YouTube. Interlochen MI
I only have 1 photo of it, It has my Favorite drum style. I will do a Vote poll. Should I keep my current White cabinet or scrap it and use the Graphite Cabinet. I would prefer the White though, I can't decide because the Graphite one is kinda more rare but I would regret scrapping the white one. I need to figure out how to make space for both cabinets. Also when did the WATER PLUS option come out. The serial Number of mine is January of 2007 and the serial of this parts unit is April 2006. If I get this machine and my Motor controller goes bad on my main unit, will this board still give me the Water plus option if it has Quick cycle option instead? IF my motor controller goes out is Water plus no longer going to be working on the older board? I hope this one has Water plus. If it doesn't and the older board won't give me water plus on me adding it. I'll just throw this board out with the scrap parts. Or is it possible if my motor controller goes bad to desolder the program chip and place it on the other board? Model WM2277HS,Spider is broken. Apparently replaced last year, is the spider made of very cheap aluminium or is this poor usage habits? I cleaned everything inside by hand and put plastic plates under the spider to slow down corrosion. If you don't know what I am talking about, take apart a Maytag Neptune, MAH3000 through MAH7500 and take the spider off and you will see the plastic plates.
