A806 help
jimmyb
Nov 15, 2004
254
Western NY
I am in the process of replacing the bearings on my Maytag A806, the outer tub has a few minor rust spots and some rust/corrosion at the bleach inlet and water drain tube - what is the best paint/product to use to prevent it from continuing.
The wash basket also has a few chips near the mounting stem - what product should I use to cover them so the chips do not become larger or rust?
Thanks in advance for your help.
yep good prep is the key but that por is great stuff. well that and marine epoxy.. but get some por and give it a try. follow the instructions and it should work great for you
Another idea...
You might also consider a donor for the inner and outer tubs... I would think that any deep tub 06, 08, 10 or 12 model washer with a bleach dispenser would be a suitable donor. The tubs SHOULD be interchangeable.
RCD
The epoxy idea mentioned above
Jim,
I have used an epoxy with some good success. I used to buy a type sold by Gemline in the 90s, and my parts store recently told me it's still available. I don't know if Supco took that over or who makes it anymore (I think Supco took over most of Gemline's laundry parts) but a good parts outlet probably knows what I'm talking about.
I am referring to a user-mixed concoction of two materials that look like modeling clay. One is gray, one is tan in color. When separate, the two materials are inert, but mixed together they form a moldable, pliable clay that hardens overnight into a seemingly impenetrable cement layer. Oddly, the mixture is gray, as the brown/tan completely dissappears.
I have used it to cover holes in tubs, or to cover up rusty rash-like areas that would probably otherwise develop into holes. Now that many if not most of the original porcelain outer tubs are becoming hard to get, I have had to become more resourceful, and this stuff seems to work well.
I have occasionally added what I think is more durability to a repair by covering the dried epoxy with sealant. Last time I used this a few weeks back I mixed up too much, and the rest I molded into a quarter sized marble - when it dried I found it indestructible - even when thrown onto my garage floor.
I've heard good things about the POR stuff here, but wouldn't hesitate to cover those areas you're referring to with epoxy.
