Accessing programming mode G7164SCVi
mielerod69
Feb 8, 2009
334
Australia
Hi,
I was hoping someone could help me access the programming mode for my Miele dishwasher. In the past, I've been able to access this with other models, but this one has stumped me.
I have attached a picture of the panel to see what keys I need to hold down and press several times.
is it like
Door open and turned off:
1) Hold down OK
2) Press the power button 5x and hold it down on the 5th? (all while holding down OK)
Service mode is the same but 3x and not 5x
I don't have the fully integrated machine, so mine is the start button.
Hold it down, power it on, pres 3x/5x and hold on the final one.
As soon as it flashes let go.
Because of the weird standby / boot behaviour I found turning it on first, waiting till it shows the remaining cycle time, switching it of and starting the sequence then helps with success.
And I am almost certain to have heard here that the OK button on these basically acts like a start button.
So it should be the same.
Thanks henene4
I will have to try again before the display lights up and shows the program because once it does that, I can't get into the programming mode using the OK key.
