I modifed my FL by adding a water level selector to my FL.
The orginal water level is 3.25" from the bottom of the inner tub, which is about 4.5 gal of water.
The new high water level is 4.5" which is about 6 gal.
The soak-up by laundry could take an extra of 1 gal.
The high water level will use 4.5 gal more water (with 1 wash + 2 rinses)
Tried a full-load this evening using high water level. It does wash and rinse better than the original low level.
Will use the high water level for full-load laundry and low water level for 1/2 load..
How to add this water level selector to my FL?
The pressure switch of FL is used to control the water level. It was discovered that there are two settings of water level in the pressure switch of my FL.
The manufacturer only uses the low level setting and not using the high level at all. Apparently they do this to get a name for water/energy efficiency at the expense of "washing/cleaning".
I added a double-pole double-throw switch to select High and Low level.
