Air Conditioners
mine is a window/wall unit.....I had to leave off the side curtains to fit the window opening....
the unit has two screws at the bottom that lock it in place, plus its screwed in from the sides to keep it secure in the window.....
there have been cases of gaining entrance into a home from thieves by sliding a screwdriver underneath, and pushing the unit into the home...
I've had our current Mitubishi mini split since I think 2010 or was it 2011. .. anyways,, the filtering system on it is crap.. most of the air goes around and behind those flexible thin filter things and then sticks on the blades of the squirell cage fan, which in turn gets bogged down and has required disassembly every 2 years, at a cost. It's currently not working and the repairman is coming in the morning.. I won't be buying another Mitsubishi mini split again unless they redesign the whole filter system.
Austin... what kind of central ac system is it you're talking about? Over here central air generally refers to a fan forced ducted furnace/air conditioner where the evaporator is in the furnace and the condenser unit sits outside. There are ductless mini split systems available with ceiling cassettes but they're much less common right now. More common is just the straight forward mini split unit set up on the wall high up,, perhaps two or 3 of those depending on the size of the house etc They all need to be wired and and the coolant tubes plumbed to the outside condenser as well as having a drain tube
AC guys showed up this a.m. and as suspected my Freon was low... so he's put in some dye and charged it up and we'll see what happens over the course of the next week or so,, if not sooner. Days I wished we just had a regular forced air furnace and air conditioner... this thing is hundreds of dollaring me to death every couple of years.. :(
@petek
I believe its the split system with the fans in the ceiling I am just so looking forward to being cooler I cannot handle the slightest increase in temperature these days.
Austin
Pete,
I've had a Climataire split system in the bedroom for 10 years and touch wood....never had a problem with it. I do clean the filters every season and I did have the service guy out to check it over a couple of years ago. Last summer I had a Carriere split system installed in the living area. I've only used it a handful of times so not sure what its reliability is going to be. It did come with a 5 year warranty.
Gary
Some good friends of my Parents
Had a huge Coldspot window unit, 28000 btu, I never saw it turned over halfway on the thermostat and the fan was always on low and their house was always cold!it lasted almost 40 years and the compressor died, I think lightning got it.
I remember back in high school going to a friends house and her parents had a huge Sears window A/C. It had a separate dial for humidity setting along with the cooling dial. I believe it was a 220v. Had never seen this before or since. Anyone ever come across one of these?
Jon
Air conditioninig article from Washington Post
This makes it sound like there will be a resurgence in domestic AC manufacturing:
<!-- [if !mso]>
<style>
v&#92:* {behavior:url(#default#VML);}
o&#92:* {behavior:url(#default#VML);}
w&#92:* {behavior:url(#default#VML);}
.shape {behavior:url(#default#VML);}
</style>
<![endif]--><!-- [if gte mso 9]><xml>
<w:WordDocument>
<w:View>Normal</w:View>
<w:Zoom>0</w:Zoom>
<w:TrackMoves/>
<w:TrackFormatting/>
<w:PunctuationKerning/>
<w:ValidateAgainstSchemas/>
<w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid>
<w:IgnoreMixedContent>false</w:IgnoreMixedContent>
<w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText>
<w:DoNotPromoteQF/>
<w:LidThemeOther>EN-US</w:LidThemeOther>
<w:LidThemeAsian>ZH-CN</w:LidThemeAsian>
<w:LidThemeComplexScript>AR-SA</w:LidThemeComplexScript>
<w:Compatibility>
<w:BreakWrappedTables/>
<w:SnapToGridInCell/>
<w:ApplyBreakingRules/>
<w:WrapTextWithPunct/>
<w:UseAsianBreakRules/>
<w:DontGrowAutofit/>
<w:SplitPgBreakAndParaMark/>
<w:EnableOpenTypeKerning/>
<w:DontFlipMirrorIndents/>
<w:OverrideTableStyleHps/>
</w:Compatibility>
<w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel>
<m:mathPr>
<m:mathFont m:val="Cambria Math"/>
<m:brkBin m:val="before"/>
<m:brkBinSub m:val="--"/>
<m:smallFrac m:val="off"/>
<m:dispDef/>
<m:lMargin m:val="0"/>
<m:rMargin m:val="0"/>
<m:defJc m:val="centerGroup"/>
<m:wrapIndent m:val="1440"/>
<m:intLim m:val="subSup"/>
<m:naryLim m:val="undOvr"/>
</m:mathPr></w:WordDocument>
</xml><![endif]--><!-- [if gte mso 9]><xml>
<w:LatentStyles DefLockedState="false" DefUnhideWhenUsed="false"
DefSemiHidden="false" DefQFormat="false" DefPriority="99"
LatentStyleCount="371">
<w:LsdException Locked="false" Priority="0" QFormat="true" Name="Normal"/>
<w:LsdException Locked="false" Priority="9" QFormat="true" Name="heading 1"/>
<w:LsdException Locked="false" Priority="9" SemiHidden="true"
UnhideWhenUsed="true" QFormat="true" Name="heading 2"/>
UnhideWhenUsed="true" QFormat="true" Name="heading 3"/>
UnhideWhenUsed="true" QFormat="true" Name="heading 4"/>
UnhideWhenUsed="true" QFormat="true" Name="heading 5"/>
UnhideWhenUsed="true" QFormat="true" Name="heading 6"/>
UnhideWhenUsed="true" QFormat="true" Name="heading 7"/>
UnhideWhenUsed="true" QFormat="true" Name="heading 8"/>
UnhideWhenUsed="true" QFormat="true" Name="heading 9"/>
<w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true"
Name="index 1"/>
Name="index 2"/>
Name="index 3"/>
Name="index 4"/>
Name="index 5"/>
Name="index 6"/>
Name="index 7"/>
Name="index 8"/>
Name="index 9"/>
<w:LsdException Locked="false" Priority="39" SemiHidden="true"
UnhideWhenUsed="true" Name="toc 1"/>
UnhideWhenUsed="true" Name="toc 2"/>
UnhideWhenUsed="true" Name="toc 3"/>
UnhideWhenUsed="true" Name="toc 4"/>
UnhideWhenUsed="true" Name="toc 5"/>
UnhideWhenUsed="true" Name="toc 6"/>
UnhideWhenUsed="true" Name="toc 7"/>
UnhideWhenUsed="true" Name="toc 8"/>
UnhideWhenUsed="true" Name="toc 9"/>
Name="Normal Indent"/>
Name="footnote text"/>
Name="annotation text"/>
Name="header"/>
Name="footer"/>
Name="index heading"/>
<w:LsdException Locked="false" Priority="35" SemiHidden="true"
UnhideWhenUsed="true" QFormat="true" Name="caption"/>
Name="table of figures"/>
Name="envelope address"/>
Name="envelope return"/>
Name="footnote reference"/>
Name="annotation reference"/>
Name="line number"/>
Name="page number"/>
Name="endnote reference"/>
Name="endnote text"/>
Name="table of authorities"/>
Name="macro"/>
Name="toa heading"/>
Name="List"/>
Name="List Bullet"/>
Name="List Number"/>
Name="List 2"/>
Name="List 3"/>
Name="List 4"/>
Name="List 5"/>
Name="List Bullet 2"/>
Name="List Bullet 3"/>
Name="List Bullet 4"/>
Name="List Bullet 5"/>
Name="List Number 2"/>
Name="List Number 3"/>
Name="List Number 4"/>
Name="List Number 5"/>
<w:LsdException Locked="false" Priority="10" QFormat="true" Name="Title"/>
Name="Closing"/>
Name="Signature"/>
<w:LsdException Locked="false" Priority="1" SemiHidden="true"
UnhideWhenUsed="true" Name="Default Paragraph Font"/>
Name="Body Text"/>
Name="Body Text Indent"/>
Name="List Continue"/>
Name="List Continue 2"/>
Name="List Continue 3"/>
Name="List Continue 4"/>
Name="List Continue 5"/>
Name="Message Header"/>
<w:LsdException Locked="false" Priority="11" QFormat="true" Name="Subtitle"/>
Name="Salutation"/>
Name="Date"/>
Name="Body Text First Indent"/>
Name="Body Text First Indent 2"/>
Name="Note Heading"/>
Name="Body Text 2"/>
Name="Body Text 3"/>
Name="Body Text Indent 2"/>
Name="Body Text Indent 3"/>
Name="Block Text"/>
Name="Hyperlink"/>
Name="FollowedHyperlink"/>
<w:LsdException Locked="false" Priority="22" QFormat="true" Name="Strong"/>
<w:LsdException Locked="false" Priority="20" QFormat="true" Name="Emphasis"/>
Name="Document Map"/>
Name="Plain Text"/>
Name="E-mail Signature"/>
Name="HTML Top of Form"/>
Name="HTML Bottom of Form"/>
Name="Normal (Web)"/>
Name="HTML Acronym"/>
Name="HTML Address"/>
Name="HTML Cite"/>
Name="HTML Code"/>
Name="HTML Definition"/>
Name="HTML Keyboard"/>
Name="HTML Preformatted"/>
Name="HTML Sample"/>
Name="HTML Typewriter"/>
Name="HTML Variable"/>
Name="Normal Table"/>
Name="annotation subject"/>
Name="No List"/>
Name="Outline List 1"/>
Name="Outline List 2"/>
Name="Outline List 3"/>
Name="Table Simple 1"/>
Name="Table Simple 2"/>
Name="Table Simple 3"/>
Name="Table Classic 1"/>
Name="Table Classic 2"/>
Name="Table Classic 3"/>
Name="Table Classic 4"/>
Name="Table Colorful 1"/>
Name="Table Colorful 2"/>
Name="Table Colorful 3"/>
Name="Table Columns 1"/>
Name="Table Columns 2"/>
Name="Table Columns 3"/>
Name="Table Columns 4"/>
Name="Table Columns 5"/>
Name="Table Grid 1"/>
Name="Table Grid 2"/>
Name="Table Grid 3"/>
Name="Table Grid 4"/>
Name="Table Grid 5"/>
Name="Table Grid 6"/>
Name="Table Grid 7"/>
Name="Table Grid 8"/>
Name="Table List 1"/>
Name="Table List 2"/>
Name="Table List 3"/>
Name="Table List 4"/>
Name="Table List 5"/>
Name="Table List 6"/>
Name="Table List 7"/>
Name="Table List 8"/>
Name="Table 3D effects 1"/>
Name="Table 3D effects 2"/>
Name="Table 3D effects 3"/>
Name="Table Contemporary"/>
Name="Table Elegant"/>
Name="Table Professional"/>
Name="Table Subtle 1"/>
Name="Table Subtle 2"/>
Name="Table Web 1"/>
Name="Table Web 2"/>
Name="Table Web 3"/>
Name="Balloon Text"/>
<w:LsdException Locked="false" Priority="39" Name="Table Grid"/>
Name="Table Theme"/>
<w:LsdException Locked="false" SemiHidden="true" Name="Placeholder Text"/>
<w:LsdException Locked="false" Priority="1" QFormat="true" Name="No Spacing"/>
<w:LsdException Locked="false" Priority="60" Name="Light Shading"/>
<w:LsdException Locked="false" Priority="61" Name="Light List"/>
<w:LsdException Locked="false" Priority="62" Name="Light Grid"/>
<w:LsdException Locked="false" Priority="63" Name="Medium Shading 1"/>
<w:LsdException Locked="false" Priority="64" Name="Medium Shading 2"/>
<w:LsdException Locked="false" Priority="65" Name="Medium List 1"/>
<w:LsdException Locked="false" Priority="66" Name="Medium List 2"/>
<w:LsdException Locked="false" Priority="67" Name="Medium Grid 1"/>
<w:LsdException Locked="false" Priority="68" Name="Medium Grid 2"/>
<w:LsdException Locked="false" Priority="69" Name="Medium Grid 3"/>
<w:LsdException Locked="false" Priority="70" Name="Dark List"/>
<w:LsdException Locked="false" Priority="71" Name="Colorful Shading"/>
<w:LsdException Locked="false" Priority="72" Name="Colorful List"/>
<w:LsdException Locked="false" Priority="73" Name="Colorful Grid"/>
<w:LsdException Locked="false" Priority="60" Name="Light Shading Accent 1"/>
<w:LsdException Locked="false" Priority="61" Name="Light List Accent 1"/>
<w:LsdException Locked="false" Priority="62" Name="Light Grid Accent 1"/>
<w:LsdException Locked="false" Priority="63" Name="Medium Shading 1 Accent 1"/>
<w:LsdException Locked="false" Priority="64" Name="Medium Shading 2 Accent 1"/>
<w:LsdException Locked="false" Priority="65" Name="Medium List 1 Accent 1"/>
<w:LsdException Locked="false" SemiHidden="true" Name="Revision"/>
<w:LsdException Locked="false" Priority="34" QFormat="true"
Name="List Paragraph"/>
<w:LsdException Locked="false" Priority="29" QFormat="true" Name="Quote"/>
<w:LsdException Locked="false" Priority="30" QFormat="true"
Name="Intense Quote"/>
<w:LsdException Locked="false" Priority="66" Name="Medium List 2 Accent 1"/>
<w:LsdException Locked="false" Priority="67" Name="Medium Grid 1 Accent 1"/>
<w:LsdException Locked="false" Priority="68" Name="Medium Grid 2 Accent 1"/>
<w:LsdException Locked="false" Priority="69" Name="Medium Grid 3 Accent 1"/>
<w:LsdException Locked="false" Priority="70" Name="Dark List Accent 1"/>
<w:LsdException Locked="false" Priority="71" Name="Colorful Shading Accent 1"/>
<w:LsdException Locked="false" Priority="72" Name="Colorful List Accent 1"/>
<w:LsdException Locked="false" Priority="73" Name="Colorful Grid Accent 1"/>
<w:LsdException Locked="false" Priority="60" Name="Light Shading Accent 2"/>
<w:LsdException Locked="false" Priority="61" Name="Light List Accent 2"/>
<w:LsdException Locked="false" Priority="62" Name="Light Grid Accent 2"/>
<w:LsdException Locked="false" Priority="63" Name="Medium Shading 1 Accent 2"/>
<w:LsdException Locked="false" Priority="64" Name="Medium Shading 2 Accent 2"/>
<w:LsdException Locked="false" Priority="65" Name="Medium List 1 Accent 2"/>
<w:LsdException Locked="false" Priority="66" Name="Medium List 2 Accent 2"/>
<w:LsdException Locked="false" Priority="67" Name="Medium Grid 1 Accent 2"/>
<w:LsdException Locked="false" Priority="68" Name="Medium Grid 2 Accent 2"/>
<w:LsdException Locked="false" Priority="69" Name="Medium Grid 3 Accent 2"/>
<w:LsdException Locked="false" Priority="70" Name="Dark List Accent 2"/>
<w:LsdException Locked="false" Priority="71" Name="Colorful Shading Accent 2"/>
<w:LsdException Locked="false" Priority="72" Name="Colorful List Accent 2"/>
<w:LsdException Locked="false" Priority="73" Name="Colorful Grid Accent 2"/>
<w:LsdException Locked="false" Priority="60" Name="Light Shading Accent 3"/>
<w:LsdException Locked="false" Priority="61" Name="Light List Accent 3"/>
<w:LsdException Locked="false" Priority="62" Name="Light Grid Accent 3"/>
<w:LsdException Locked="false" Priority="63" Name="Medium Shading 1 Accent 3"/>
<w:LsdException Locked="false" Priority="64" Name="Medium Shading 2 Accent 3"/>
<w:LsdException Locked="false" Priority="65" Name="Medium List 1 Accent 3"/>
<w:LsdException Locked="false" Priority="66" Name="Medium List 2 Accent 3"/>
<w:LsdException Locked="false" Priority="67" Name="Medium Grid 1 Accent 3"/>
<w:LsdException Locked="false" Priority="68" Name="Medium Grid 2 Accent 3"/>
<w:LsdException Locked="false" Priority="69" Name="Medium Grid 3 Accent 3"/>
<w:LsdException Locked="false" Priority="70" Name="Dark List Accent 3"/>
<w:LsdException Locked="false" Priority="71" Name="Colorful Shading Accent 3"/>
<w:LsdException Locked="false" Priority="72" Name="Colorful List Accent 3"/>
<w:LsdException Locked="false" Priority="73" Name="Colorful Grid Accent 3"/>
<w:LsdException Locked="false" Priority="60" Name="Light Shading Accent 4"/>
<w:LsdException Locked="false" Priority="61" Name="Light List Accent 4"/>
<w:LsdException Locked="false" Priority="62" Name="Light Grid Accent 4"/>
<w:LsdException Locked="false" Priority="63" Name="Medium Shading 1 Accent 4"/>
<w:LsdException Locked="false" Priority="64" Name="Medium Shading 2 Accent 4"/>
<w:LsdException Locked="false" Priority="65" Name="Medium List 1 Accent 4"/>
<w:LsdException Locked="false" Priority="66" Name="Medium List 2 Accent 4"/>
<w:LsdException Locked="false" Priority="67" Name="Medium Grid 1 Accent 4"/>
<w:LsdException Locked="false" Priority="68" Name="Medium Grid 2 Accent 4"/>
<w:LsdException Locked="false" Priority="69" Name="Medium Grid 3 Accent 4"/>
<w:LsdException Locked="false" Priority="70" Name="Dark List Accent 4"/>
<w:LsdException Locked="false" Priority="71" Name="Colorful Shading Accent 4"/>
<w:LsdException Locked="false" Priority="72" Name="Colorful List Accent 4"/>
<w:LsdException Locked="false" Priority="73" Name="Colorful Grid Accent 4"/>
<w:LsdException Locked="false" Priority="60" Name="Light Shading Accent 5"/>
<w:LsdException Locked="false" Priority="61" Name="Light List Accent 5"/>
<w:LsdException Locked="false" Priority="62" Name="Light Grid Accent 5"/>
<w:LsdException Locked="false" Priority="63" Name="Medium Shading 1 Accent 5"/>
<w:LsdException Locked="false" Priority="64" Name="Medium Shading 2 Accent 5"/>
<w:LsdException Locked="false" Priority="65" Name="Medium List 1 Accent 5"/>
<w:LsdException Locked="false" Priority="66" Name="Medium List 2 Accent 5"/>
<w:LsdException Locked="false" Priority="67" Name="Medium Grid 1 Accent 5"/>
<w:LsdException Locked="false" Priority="68" Name="Medium Grid 2 Accent 5"/>
<w:LsdException Locked="false" Priority="69" Name="Medium Grid 3 Accent 5"/>
<w:LsdException Locked="false" Priority="70" Name="Dark List Accent 5"/>
<w:LsdException Locked="false" Priority="71" Name="Colorful Shading Accent 5"/>
<w:LsdException Locked="false" Priority="72" Name="Colorful List Accent 5"/>
<w:LsdException Locked="false" Priority="73" Name="Colorful Grid Accent 5"/>
<w:LsdException Locked="false" Priority="60" Name="Light Shading Accent 6"/>
<w:LsdException Locked="false" Priority="61" Name="Light List Accent 6"/>
<w:LsdException Locked="false" Priority="62" Name="Light Grid Accent 6"/>
<w:LsdException Locked="false" Priority="63" Name="Medium Shading 1 Accent 6"/>
<w:LsdException Locked="false" Priority="64" Name="Medium Shading 2 Accent 6"/>
<w:LsdException Locked="false" Priority="65" Name="Medium List 1 Accent 6"/>
<w:LsdException Locked="false" Priority="66" Name="Medium List 2 Accent 6"/>
<w:LsdException Locked="false" Priority="67" Name="Medium Grid 1 Accent 6"/>
<w:LsdException Locked="false" Priority="68" Name="Medium Grid 2 Accent 6"/>
<w:LsdException Locked="false" Priority="69" Name="Medium Grid 3 Accent 6"/>
<w:LsdException Locked="false" Priority="70" Name="Dark List Accent 6"/>
<w:LsdException Locked="false" Priority="71" Name="Colorful Shading Accent 6"/>
<w:LsdException Locked="false" Priority="72" Name="Colorful List Accent 6"/>
<w:LsdException Locked="false" Priority="73" Name="Colorful Grid Accent 6"/>
<w:LsdException Locked="false" Priority="19" QFormat="true"
Name="Subtle Emphasis"/>
<w:LsdException Locked="false" Priority="21" QFormat="true"
Name="Intense Emphasis"/>
<w:LsdException Locked="false" Priority="31" QFormat="true"
Name="Subtle Reference"/>
<w:LsdException Locked="false" Priority="32" QFormat="true"
Name="Intense Reference"/>
<w:LsdException Locked="false" Priority="33" QFormat="true" Name="Book Title"/>
<w:LsdException Locked="false" Priority="37" SemiHidden="true"
UnhideWhenUsed="true" Name="Bibliography"/>
UnhideWhenUsed="true" QFormat="true" Name="TOC Heading"/>
<w:LsdException Locked="false" Priority="41" Name="Plain Table 1"/>
<w:LsdException Locked="false" Priority="42" Name="Plain Table 2"/>
<w:LsdException Locked="false" Priority="43" Name="Plain Table 3"/>
<w:LsdException Locked="false" Priority="44" Name="Plain Table 4"/>
<w:LsdException Locked="false" Priority="45" Name="Plain Table 5"/>
<w:LsdException Locked="false" Priority="40" Name="Grid Table Light"/>
<w:LsdException Locked="false" Priority="46" Name="Grid Table 1 Light"/>
<w:LsdException Locked="false" Priority="47" Name="Grid Table 2"/>
<w:LsdException Locked="false" Priority="48" Name="Grid Table 3"/>
<w:LsdException Locked="false" Priority="49" Name="Grid Table 4"/>
<w:LsdException Locked="false" Priority="50" Name="Grid Table 5 Dark"/>
<w:LsdException Locked="false" Priority="51" Name="Grid Table 6 Colorful"/>
<w:LsdException Locked="false" Priority="52" Name="Grid Table 7 Colorful"/>
Name="Grid Table 1 Light Accent 1"/>
<w:LsdException Locked="false" Priority="47" Name="Grid Table 2 Accent 1"/>
<w:LsdException Locked="false" Priority="48" Name="Grid Table 3 Accent 1"/>
<w:LsdException Locked="false" Priority="49" Name="Grid Table 4 Accent 1"/>
<w:LsdException Locked="false" Priority="50" Name="Grid Table 5 Dark Accent 1"/>
Name="Grid Table 6 Colorful Accent 1"/>
Name="Grid Table 7 Colorful Accent 1"/>
Name="Grid Table 1 Light Accent 2"/>
<w:LsdException Locked="false" Priority="47" Name="Grid Table 2 Accent 2"/>
<w:LsdException Locked="false" Priority="48" Name="Grid Table 3 Accent 2"/>
<w:LsdException Locked="false" Priority="49" Name="Grid Table 4 Accent 2"/>
<w:LsdException Locked="false" Priority="50" Name="Grid Table 5 Dark Accent 2"/>
Name="Grid Table 6 Colorful Accent 2"/>
Name="Grid Table 7 Colorful Accent 2"/>
Name="Grid Table 1 Light Accent 3"/>
<w:LsdException Locked="false" Priority="47" Name="Grid Table 2 Accent 3"/>
<w:LsdException Locked="false" Priority="48" Name="Grid Table 3 Accent 3"/>
<w:LsdException Locked="false" Priority="49" Name="Grid Table 4 Accent 3"/>
<w:LsdException Locked="false" Priority="50" Name="Grid Table 5 Dark Accent 3"/>
Name="Grid Table 6 Colorful Accent 3"/>
Name="Grid Table 7 Colorful Accent 3"/>
Name="Grid Table 1 Light Accent 4"/>
<w:LsdException Locked="false" Priority="47" Name="Grid Table 2 Accent 4"/>
<w:LsdException Locked="false" Priority="48" Name="Grid Table 3 Accent 4"/>
<w:LsdException Locked="false" Priority="49" Name="Grid Table 4 Accent 4"/>
<w:LsdException Locked="false" Priority="50" Name="Grid Table 5 Dark Accent 4"/>
Name="Grid Table 6 Colorful Accent 4"/>
Name="Grid Table 7 Colorful Accent 4"/>
Name="Grid Table 1 Light Accent 5"/>
<w:LsdException Locked="false" Priority="47" Name="Grid Table 2 Accent 5"/>
<w:LsdException Locked="false" Priority="48" Name="Grid Table 3 Accent 5"/>
<w:LsdException Locked="false" Priority="49" Name="Grid Table 4 Accent 5"/>
<w:LsdException Locked="false" Priority="50" Name="Grid Table 5 Dark Accent 5"/>
Name="Grid Table 6 Colorful Accent 5"/>
Name="Grid Table 7 Colorful Accent 5"/>
Name="Grid Table 1 Light Accent 6"/>
<w:LsdException Locked="false" Priority="47" Name="Grid Table 2 Accent 6"/>
<w:LsdException Locked="false" Priority="48" Name="Grid Table 3 Accent 6"/>
<w:LsdException Locked="false" Priority="49" Name="Grid Table 4 Accent 6"/>
<w:LsdException Locked="false" Priority="50" Name="Grid Table 5 Dark Accent 6"/>
Name="Grid Table 6 Colorful Accent 6"/>
Name="Grid Table 7 Colorful Accent 6"/>
<w:LsdException Locked="false" Priority="46" Name="List Table 1 Light"/>
<w:LsdException Locked="false" Priority="47" Name="List Table 2"/>
<w:LsdException Locked="false" Priority="48" Name="List Table 3"/>
<w:LsdException Locked="false" Priority="49" Name="List Table 4"/>
<w:LsdException Locked="false" Priority="50" Name="List Table 5 Dark"/>
<w:LsdException Locked="false" Priority="51" Name="List Table 6 Colorful"/>
<w:LsdException Locked="false" Priority="52" Name="List Table 7 Colorful"/>
Name="List Table 1 Light Accent 1"/>
<w:LsdException Locked="false" Priority="47" Name="List Table 2 Accent 1"/>
<w:LsdException Locked="false" Priority="48" Name="List Table 3 Accent 1"/>
<w:LsdException Locked="false" Priority="49" Name="List Table 4 Accent 1"/>
<w:LsdException Locked="false" Priority="50" Name="List Table 5 Dark Accent 1"/>
Name="List Table 6 Colorful Accent 1"/>
Name="List Table 7 Colorful Accent 1"/>
Name="List Table 1 Light Accent 2"/>
<w:LsdException Locked="false" Priority="47" Name="List Table 2 Accent 2"/>
<w:LsdException Locked="false" Priority="48" Name="List Table 3 Accent 2"/>
<w:LsdException Locked="false" Priority="49" Name="List Table 4 Accent 2"/>
<w:LsdException Locked="false" Priority="50" Name="List Table 5 Dark Accent 2"/>
Name="List Table 6 Colorful Accent 2"/>
Name="List Table 7 Colorful Accent 2"/>
Name="List Table 1 Light Accent 3"/>
<w:LsdException Locked="false" Priority="47" Name="List Table 2 Accent 3"/>
<w:LsdException Locked="false" Priority="48" Name="List Table 3 Accent 3"/>
<w:LsdException Locked="false" Priority="49" Name="List Table 4 Accent 3"/>
<w:LsdException Locked="false" Priority="50" Name="List Table 5 Dark Accent 3"/>
Name="List Table 6 Colorful Accent 3"/>
Name="List Table 7 Colorful Accent 3"/>
Name="List Table 1 Light Accent 4"/>
<w:LsdException Locked="false" Priority="47" Name="List Table 2 Accent 4"/>
<w:LsdException Locked="false" Priority="48" Name="List Table 3 Accent 4"/>
<w:LsdException Locked="false" Priority="49" Name="List Table 4 Accent 4"/>
<w:LsdException Locked="false" Priority="50" Name="List Table 5 Dark Accent 4"/>
Name="List Table 6 Colorful Accent 4"/>
Name="List Table 7 Colorful Accent 4"/>
Name="List Table 1 Light Accent 5"/>
<w:LsdException Locked="false" Priority="47" Name="List Table 2 Accent 5"/>
<w:LsdException Locked="false" Priority="48" Name="List Table 3 Accent 5"/>
<w:LsdException Locked="false" Priority="49" Name="List Table 4 Accent 5"/>
<w:LsdException Locked="false" Priority="50" Name="List Table 5 Dark Accent 5"/>
Name="List Table 6 Colorful Accent 5"/>
Name="List Table 7 Colorful Accent 5"/>
Name="List Table 1 Light Accent 6"/>
<w:LsdException Locked="false" Priority="47" Name="List Table 2 Accent 6"/>
<w:LsdException Locked="false" Priority="48" Name="List Table 3 Accent 6"/>
<w:LsdException Locked="false" Priority="49" Name="List Table 4 Accent 6"/>
<w:LsdException Locked="false" Priority="50" Name="List Table 5 Dark Accent 6"/>
Name="List Table 6 Colorful Accent 6"/>
Name="List Table 7 Colorful Accent 6"/>
</w:LatentStyles>
</xml><![endif]--><!-- [if gte mso 10]>
<style>
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-priority:99;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman",serif;}
</style>
<![endif]-->
<span style="mso-fareast-font-family: 'Times New Roman';"> </span>
imp
</span>
imp
</span>
<span style="mso-fareast-font-family: 'Times New Roman'; display: none; mso-hide: all;"> </span>
Analysis on the energy and environment debate. Not on the list? Sign up here.
<span style="font-size: 1.0pt; mso-fareast-font-family: 'Times New Roman';">
</span>
<span style="mso-fareast-font-family: 'Times New Roman';"><span style="font-family: 'Arial',sans-serif; color: #333333;"> </span></span>
<span style="font-size: 18.0pt; font-family: 'Helvetica',sans-serif; mso-fareast-font-family: 'Times New Roman'; color: black;">Your daily policy charge </span>
<span style="font-size: 10.5pt; font-family: 'Helvetica',sans-serif; mso-fareast-font-family: 'Times New Roman'; color: #6b6b6b;"><span style="font-family: 'Arial',sans-serif; color: #6b6b6b; border: none windowtext 1.0pt; mso-border-alt: none windowtext 0in; padding: 0in;">   Share </span></span>
<span style="font-size: 10.5pt; font-family: 'Helvetica',sans-serif; mso-fareast-font-family: 'Times New Roman'; color: #6b6b6b;"><span style="font-family: 'Arial',sans-serif; color: #6b6b6b; border: none windowtext 1.0pt; mso-border-alt: none windowtext 0in; padding: 0in;">   Tips/Feedback </span></span>
<span style="font-size: 16.5pt; font-family: 'Arial',sans-serif; mso-fareast-font-family: 'Times New Roman'; color: #2a2a2a;">Republicans can't agree on this climate deal brokered by Obama </span>
<span style="mso-fareast-font-family: 'Times New Roman';"><span style="font-family: 'Arial',sans-serif; color: #2c2c2c; text-transform: uppercase;"> </span></span>
<span style="mso-fareast-font-family: 'Times New Roman';"><span style="font-family: 'Arial',sans-serif; color: #2c2c2c; text-transform: uppercase;">BY DINO GRANDONI</span> </span>
<span style="font-size: 10.5pt; font-family: 'Arial',sans-serif; mso-fareast-font-family: 'Times New Roman';">with Paulina Firozi</span>
<span style="font-size: 13.5pt; font-family: 'Helvetica',sans-serif; color: #1955a5;">THE LIGHTBULB</span>
<span style="font-size: 13.5pt; font-family: 'Helvetica',sans-serif; mso-fareast-font-family: 'Times New Roman'; color: #2a2a2a;">
</span>
<span style="font-family: 'Helvetica',sans-serif;">(iStock)</span>
<span style="font-size: 13.5pt; font-family: 'Helvetica',sans-serif; color: #2a2a2a;">Republicans are happy to see the Trump administration do away with most of the climate policies of the previous president — or at least try to. But conservative politicians and activists are deeply divided over whether to cement into law a hard-fought international agreement on a set of little-known greenhouse gases.</span>
<span style="font-size: 13.5pt; font-family: 'Helvetica',sans-serif; color: #2a2a2a;">The tiff concerns a multilateral effort to phase out hydrofluorocarbons, or HFCs. That class of organic compounds, which are used in but also leak from air conditioners, pose a duel threat to the planet: They erode Earth's protective ozone layer and amplify the greenhouse effect.</span>
<span style="font-size: 13.5pt; font-family: 'Helvetica',sans-serif; color: #2a2a2a;">In President Barack Obama's final full year in office, his administration negotiated an amendment to the landmark Montreal Protocol attempting to curtail their use. But conservatives are divided about whether they should ratify the changes to the treaty now that they are in charge.</span>
<span style="font-size: 13.5pt; font-family: 'Helvetica',sans-serif; color: #2a2a2a;">On the one side of the debate is much of the U.S. cooling industry</span><span style="font-size: 13.5pt; font-family: 'Helvetica',sans-serif; color: #2a2a2a;">, which supports what is called the Kigali Amendment, after the Rwandan city in which it was negotiated.</span>
<span style="font-size: 13.5pt; font-family: 'Helvetica',sans-serif; color: #2a2a2a;">Domestic manufacturers want to make sure they are not shut out of the international market for the next generation of air conditioners as millions in sweltering nations in Asia, Africa and South America rise from poverty to buy cooling systems (all while temperatures climb, too).</span>
<span style="font-size: 13.5pt; font-family: 'Helvetica',sans-serif; color: #2a2a2a;">Even the tea party-aligned group FreedomWorks touted the job-creating potential of the amendment in a letter last month. And for once, environmentalists and manufacturers are largely on the same page regarding a climate treaty.</span>
<span style="font-size: 13.5pt; font-family: 'Helvetica',sans-serif; color: #2a2a2a;">“That’s not particularly common,” said Francis Dietz, spokesman for the Air-Conditioning, Heating and Refrigeration Institute (AHRI), an industry group.</span>
<span style="font-size: 13.5pt; font-family: 'Helvetica',sans-serif; color: #2a2a2a;">On the other side are strident critics of climate-change science and mitigation efforts who do not want to see the ozone-layer treaty being used to fight climate change.</span>
<span style="font-size: 13.5pt; font-family: 'Helvetica',sans-serif; color: #2a2a2a;">The latest firework occurred last week when the leaders of two dozen conservative groups wrote to President Trump pleading with him to reject the amendment.</span>
<span style="font-size: 13.5pt; font-family: 'Helvetica',sans-serif; color: #2a2a2a;">“The Kigali Amendment would not advance the purpose of the Montreal Protocol,” said the letter, organized by the Competitive Enterprise Institute, “but would instead turn a treaty aimed at saving the ozone layer into a global-warming treaty.”</span>
<span style="font-size: 13.5pt; font-family: 'Helvetica',sans-serif; color: #2a2a2a;">The amendment, like all treaties, must be submitted by the president to the Senate for approval. A two-thirds supermajority in the upper chamber must ratify it to become law.</span>
<span style="font-size: 13.5pt; font-family: 'Helvetica',sans-serif; color: #2a2a2a;">But the HFC provision has a decent chance of meeting that high margin even in the GOP-controlled chamber. </span><span style="font-size: 13.5pt; font-family: 'Helvetica',sans-serif; color: #2a2a2a;">Already 13 Senate Republicans, ranging from moderates such as Susan Collins (Maine) to solid conservatives such as Tim Scott (S.C.), urged Trump in a letter to send them the treaty amendment.</span>
<span style="font-size: 13.5pt; font-family: 'Helvetica',sans-serif; color: #2a2a2a;">In a sign of the political times, the senators' letter to Trump does not once mention the phrases “climate change” or “global warming.”</span>
<span style="font-size: 13.5pt; font-family: 'Helvetica',sans-serif; color: #2a2a2a;">Instead, the senators focus on potential job losses to China should the United States fail to ratify. GOP Sen. John Kennedy, whose state of Louisiana is home to Honeywell and Mexichem Fluor factories involved in refrigerant manufacturing, led the petition to Trump.</span>
<span style="font-size: 13.5pt; font-family: 'Helvetica',sans-serif; color: #2a2a2a;">“By sending this amendment to the Senate, you will help secure America’s place as the global leader in several manufacturing industries, and in turn give American workers an advantage against their competitors in the international marketplace,” the senators said.</span>
<span style="font-size: 13.5pt; font-family: 'Helvetica',sans-serif; color: #2a2a2a;">But the Trump administration has for months delayed making a decision on whether to send the treaty to the Senate.</span><span style="font-size: 13.5pt; font-family: 'Helvetica',sans-serif; color: #2a2a2a;"> In February, White House energy and climate adviser George David Banks said the Trump administration wanted “really good economic information” before coming to a decision on Kigali.</span>
<span style="font-size: 13.5pt; font-family: 'Helvetica',sans-serif; color: #2a2a2a;">So AHRI hired consultants to interview companies and model the impact of the amendment. In a report published in April, the industry association projected ratifying Kigali would create an additional 33,000 jobs by 2027.</span>
<span style="font-size: 13.5pt; font-family: 'Helvetica',sans-serif; color: #2a2a2a;">“The White House staff asked us to provide information on the jobs and trade benefits of Kigali ratification,” said Kevin Fay, head of the government affairs firm Alcalde & Fay. “We believe the strong economic analysis speaks for itself.”</span>
<span style="font-size: 13.5pt; font-family: 'Helvetica',sans-serif; color: #2a2a2a;">But Trump still has yet to act.</span>
<span style="font-size: 13.5pt; font-family: 'Helvetica',sans-serif; color: #2a2a2a;">Banks, who left the White House this year and says he supports ratifying Kigali “150 percent,” said there were still concerns among some members of the Trump administration over the cost to consumers of transitioning away from HFCs.</span>
<span style="font-size: 13.5pt; font-family: 'Helvetica',sans-serif; color: #2a2a2a;">The Heritage Foundation, a conservative think tank that has proven to be influential in the Trump White House and that opposes expanding the scope of the Montreal Protocol to address climate change, issued its own counter-report arguing that phasing down HFCs would “impose substantial costs on American families” through higher air-conditioning and refrigerator prices.</span>
<span style="font-size: 13.5pt; font-family: 'Helvetica',sans-serif; color: #2a2a2a;">“I would add that nothing is preventing businesses or families from switching,” said Nick Loris, a energy and environmental policy analyst at Heritage. “If they are cost-competitive, the market will make that transition.”</span>
<span style="font-size: 13.5pt; font-family: 'Helvetica',sans-serif; color: #2a2a2a;">In response, the air-conditioning industry says cooling chemicals constitute a small fraction of the cost of new equipment and that, like with flat-screen televisions, that expense is falling over time.</span>
<span style="font-size: 13.5pt; font-family: 'Helvetica',sans-serif; color: #2a2a2a;">Given the blue-collar factory jobs at stake, Banks says he is “bullish” on Trump supporting Kigali.</span>
<span style="font-size: 13.5pt; font-family: 'Helvetica',sans-serif; color: #2a2a2a;">“The president is not going to trade away a portion of the U.S. manufacturing base just so consumers can save a little in the short term,” Banks said.</span>
<span style="font-size: 13.5pt; font-family: 'Helvetica',sans-serif; color: #2a2a2a;">With the midterm elections approaching and a Supreme Court nomination on the docket, time is quickly evaporating for senators to approve the amendment this year if Trump sent it to them.</span>
<span style="font-size: 13.5pt; font-family: 'Helvetica',sans-serif; color: #2a2a2a;">But refrigerant manufacturers say time is on their side. The United States could face trade restrictions beginning in the 2030s if the United States does not agree to the provision.</span>
<span style="font-size: 13.5pt; font-family: 'Helvetica',sans-serif; color: #2a2a2a;">With or without U.S. backing, enough nations have signed the amendment for it to go into force next year.</span>
<span style="font-size: 19.5pt; font-family: 'Arial',sans-serif; mso-fareast-font-family: 'Times New Roman'; color: #585858;">You are reading </span><span style="font-size: 21.0pt; font-family: 'Helvetica',sans-serif; mso-fareast-font-family: 'Times New Roman'; color: #585858;">The Energy 202,</span><span style="font-size: 19.5pt; font-family: 'Arial',sans-serif; mso-fareast-font-family: 'Times New Roman'; color: #585858;"> our must-read tipsheet on energy and the environment. </span>
<span style="font-size: 15.0pt; font-family: 'Arial',sans-serif; mso-fareast-font-family: 'Times New Roman'; color: #585858;">Not a regular subscriber? </span>
<span style="font-size: 15.0pt; mso-fareast-font-family: 'Times New Roman'; color: #585858;"> </span>
<span style="font-family: 'Arial',sans-serif; mso-fareast-font-family: 'Times New Roman';"><span style="font-size: 10.5pt; font-family: 'Helvetica',sans-serif; color: white;">SIGN UP NOW </span></span>
<span style="font-size: 13.5pt; font-family: 'Helvetica',sans-serif; mso-fareast-font-family: 'Times New Roman'; color: white;">POWER PLAYS</span>
We have a 1998 7800 btu Panasonic in the living room, and absolutely love it. Super quiet and ice cold. A 5100 Btu 1997 Hampton Bay (Fedders) in my room. Ice cold and typically very quiet, but the fan motor started squeaking tonight, will dig in tomorrow and see if it can be oiled, would hate to have to replace it! And, a 5100 Btu SoleusAir (new this summer) that is not as cold, and louder than the other two combined, and gives new meaning to the term "window shaker", no, wall/house shaker! Not at all happy with it! Hopefully mine can be fixed or I may end up with one of those!
I don't want to hijack this thread, but i now have a question.
the 12k btu Kenmore elite window A/C i mentioned above is installed in the living room, but I'm seriously thinking about moving it to my bedroom.
However, the living room has security bars (apartment is on 2nd floor, but the window is right above the stairs) and my bedroom doesn't.
When I installed it, i didn't screw it on the window sash because i don't want to drill three tiny holes and then end up with a landlord making me pay to replace the window after I move out. (we never know, right?)
The A/C seems to be safe even without the screws and outside, less than 1/4 of na inch below it there are the security bars (a "box" as they were made thinking of leaving space for an A/C) so, if something goes wrong and the A/C falls outside, the super sturdy bar will hold it in place.
Now in my bedroom there are no bars.
Is there any way to make a safe installation WITHOUT drilling? If the A/C falls, it won't only destroy the A/C, but it will fall right on Darryl's car that is usually parked right under the window.
Other thing i noticed. The compressor is in a strange position, near the front of the unit. As a designer, I immediatelly guessed it is to make the front much heavier (most of the weight right on the sash) and there are also concrete counterweights on the front.
Other thing to consider. This is California, we have great wines, great weather but somethines things get a little, let's say, "agitated" here.
Mr. Slim
For all of the hundreds and thousands of mini-split air conditioning units out there all over the world the operational pitfalls are not unique to any one brand. A company in Australia has developed an ingenious service system for these units that eradicates the micron dust particles that collect on the cooling coils, the gunk that sticks to the barrel fan and most importantly the mold and mildew that thrives in the inner sanctums of these units. Watch the video, you will be truly amazed.
http://hydrokleen Air Conditioner Clean Demonstration - YouTube
Well, sounds like my bedroom unit is on borrowed time.. Managed to get rid of the squeaking/squealing but now it rattles. Plus the coils are pretty corroded, likely from a mistake years ago when it had a bad case of black mildew... Soaked the whole thing down inside and out with straight clorox, then hosed it out. I didn't realize at the time that bleach is corrosive to aluminum... But it's still chugging along, even though it's a little worse for the wear. Will hate to see it go but will probably replace it next year.
PTAC units
Recently, the Freidrich PTAC (heat and cool) unit we had in our added-on Champion sunroom finally gave up the ghost after 11 years, and we were faced with a choice. This would be an ideal time to take out the unattractive, noisy PTAC and get a quiet, remote-controlled, hidden away mini-split system.
However, the mini-split system was going to be $3,800.00 installed, and we would still be left with a hole in the sunroom wall where the PTAC lived. Champion wasn't going to repair that for free, and coordinating the mini-split installation and the PTAC hole repair (so the HVAC guys could take the old PTAC away and not have us left with a piece of plastic over the hole until the Champion people got there) was next to impossible.
So, I held my nose and had another PTAC (Amana, this time) installed in the existing wall sleeve for $2,495.00. It fit perfectly (and installed -professionally- QUICKLY) in the existing sleeve, and is quiet and seems to work very well. This was 2 months ago.
Both PTAC's are USA made by Goodman AC in Texas, which may be foreign owned.
I suppose I could have bought another Friedrich unit online (for $995 with free shipping) and installed it myself, but that's above my skill level.
http://https//www.amana-ptac.com/products/ptac/pth154g-heat-pump
And it's a good thing Daikin bought Goodman
They have constructed a brand new facility outside of Houston TX where all residential and commercial units will be made.   That means US jobs rather than Carrier, Trane, Lennox, and Nortek scrambling to create jobs in Mexico.
And as opposed to the brown turds of yesteryear, quality has improved dramatically.  Like any other unit, if properly sized and installed they carry the freight as well as the more expensive brands.
The last couple of very small (5K to 6K BTU) ones I have bought have been LOUD when their compressors turn on.  I mean window-rattling loud.  We owned a few different window ACs growing up and I do not remember any of them being so loud, but admittedly it was a long time ago and maybe I just don't remember accurately.
It's great that they are light, energy efficient and cheap today but it would be nice to be able to get a quiet one.  My next one may be vintage but I hate to lose the efficiency of the new ones.
