"always a good idea to buy a BTU rating for your space with a little bit of overkill.... "
That is interesting since have always been told and or researched the opposite; that something slightly smaller is better than larger when it comes to air conditioning.
Rationale being that an oversized unit will cycle off sooner than it should thus not remove moisture from air to make things comfortable.
Not exactly same, but during past heat wave noticed that if set the WallMaster to 72F or 73F it cooled things nicely and didn't cycle on and off much. OTOH if thermostat was set to 75F the thing cycled constantly to point of being annoying.
Since everyone is going on about split AC:
http://https//www.hgtv.com/remodel/mechanical-systems/is-ductless-heating-and-cooling-right-for-you
