You're correct imperial70 so I will comment on some of
"The warm water setting is a joke if you live in a cold climate during the winter. The water comes out cool at best."----I agree. In fact, I am researching a workaround on this so I don't have to start hot fill then move to warm to get an actual warm wash.
"I did have to wipe out the polishing compound that was left behind"---I did not have this problem nor did my dad.
"The timer is very cheap. Not like the positive feeling that Whirlpool/Kenmore offered"-----I can't compare to a WK machine but I don't see any less cheapness than compared to the GE Profile I used to own.
"It is a huge water hog. If you don't have any worries about that then this is a non-issue"----No more so than the GE it replaced (a 1999 unit from Monkey Wards). But it cleans well so if it. I want my laundry clean, not done in a way that fits a bureaucrat's agenda.
" I can tell it's going to eat belts. I don't do any heavy loads and there is belt dust all over the bottom of the unit. I really should order a spare belt. " -----Can't say, I have yet to pull the front off to have a look. But if what you say is true, then I will get a spare belt too.
"The hole design in the tub does not suck water through them during the spin cycle. When the machine completes there is visible moisture on the walls and floor of the tub"----Agreed. And guess what, same thing with the GE. Even worse in the GE if it had to deal with a moderately unbalanced load and it was a neutral drain machine too. I notice no more wetness in the clothes than I did with the GE.
