Forgive my delay in response to your questions Bob, et. al., I hadn't been following up on the thread.
Tolivac answered your questions about Babcock-Wilcox. They are still active as a boiler making company and also produce steam generators for PWR (pressurized Water Reactors).
They still provide some support for the nuclear industry, but no longer actively design or build nuclear power plants. They were the number three company in the U.S. building nuclear power plants (behind Westinghouse and GE.)
As far as the start-up test on the turbines, without the reactor being critical and producing steam...plants generally have small auxillary boilers, that are coal or gas fired. These are used to provide steam for the start up testing for the turbines and generators. (They want to make sure everything is functioning before the reactor goes live, or "critical".
Even though the reactor itself has not gone critical, there are many other systems in the plant that are live. Radiation/safety monitoring systems, turbine systems, generator systems. systems to monitor the power grid the plants feeds into, etc.
Long before the reactor is brought on line, the control room will be lit up like a Christmas tree during the preliminary, start up and test phases.
In answer to your question about GE BWR's. Yes, personally I like the GE BWR over Westinghouse's and Babcock-Wilcox PWR's.
In the BWR systems steam is taken directly from the reactor core and delivered to the turbines.
In the PWR you have an extra loop. Steam from the reactor core goes to a steam generator, which you might compare to a radiator in a car, and heats water in a secondary loop and converts it to steam. The steam from the secondary loop then turns the turbines.
The GE BWR is simpler in concept and MUCH easier to operate, as you have less systems to monitor and control. They are very reliable.
The steam temperture and pressures are less than in a PWR and therefore less likely to cause a pipe rupture or damage.
The disadvantage is that the steam coming our of the reactor core is slightly radioactive, so the turbines need to be in a shielded building.
The Westinghouse/Babcock units have turbines in regular buildings as the steam, (theoretically) has never been in the reactor core and is not radioactive.
However, in reality, the thousands of small thin tubes in the steam generators many times develop leaks and contaminate the turbines anyway. Steam generators are the most trouble-prone part of a nuclear plant. Shutting down a steam generator to repair it is costly. Most PWR reactors have two steam generators. One can be shut down for repairs while the other can continue to operate.
Temperature and pressures are higher in the PWR, so you have a slightly higher operating efficiency.
The GE BWR's, though, have a slightly higher operating capacity factor due to greater reliability and less down time Usually in the high ninety percentiles. The GE Limerick power plant in Pensylvania has been operating in excess of designed capacity and has been given a 100.6% operating capacity rating.
PWR's usually are in the low to mid nineties in capacity factor.
Both BWR and PWR have operating capacity factors greater than fossil fired plants, which average 71% capacity factor or less.
That is why electricity from nuclear power plants (both BWR and PWR) cost so much less than that from oil, gas or coal.
Barry
Barry
