Anyone know anything about Kirby Vacuums?
rpm
Mar 11, 2008
312
I was using it today and it seem to be having little power surges, the light was sort of going dim then bright.
Just as I was going to shut it off there was a burning smell and a spark out the on off button.
Does this sound like a big expense coming up?
The nearest vacuum repair is an hour away. Is it worth the drive or just send it to the curb?
Sounds like...
Maybe it needs new carbon brushes...
That's probably a worthy repair. Kirbys are well built, and good machines. Are you its original owner? And what's the model number?
~Fred
I am not the original owner, I got it free. The model is 2hc.
It is a Heritage 2. I just spent $50.00 getting new bags and a fill tube for it last week.
I wouldn't mind spending $100.00 to get it fixed as I have started to like it.
Hmmm... I like Kirbys and old vacs, but you could probably find a used G series for around 100 bucks. I don't know if haivng a self-propelled is important to you or not. Collectors like the Heritage, but I don't think of them as daily drivers... I'd much prefer a G series with a transmission... but everyone has their preferences. The thing is, if the motor is shot and you want another Heritage, you may even be able to find a used one for 25 bucks.
If it were a G series, I'd say to get it fixed without hesitation.
I know since you just invested money into it, it may be hard to give it up. Let us know what you decide!
Being a Kirby (and if you like it) I would do the hour drive. It could be the brushes, or even the switch. Kirby's are almost always worth fixing. Good luck!
May as well get it fixed. They are surprsingly easy to fix yourself btw if you are somewhat handy. If you can confirm it's the switch just buy a replacement and do it yourself. I've got 6 or 8 Kirbys of various ages and never had any problems.
RPM,
My mom's Kirby had a similar problem, all signs pointed to the switch/socket assembly. I believe hers is a Heritage 2 with the 3 prong connector. I opened things up and the assembly ohmed out fine. All said and done, it was actually the cord! An intermittent-open had developed within the female pins on the vac side of the cord. Bypassing with alligator clips confirmed.
While running, do things get better/worse if you side-load the connector/cord at the vacuum?
I just took a look at the socket where the cord plugs in.
The left prong is all black and the left side of the cord is melted,Is that a cord problem or a socket,switch problem?
The lady I talked to on the phone was really nice and said it didn't sound too serious to her.She thought about $40.00 to fix it.
When I asked her if it was worth fixing or sending it to the curb she said, God no, You buy a Kirby and own it for life, don't throw it out.
Personally I would never buy one but I am impressed by the suction and the look of it.
Here's my Heritage,is it the same one
I would spend the money to repair it.
The surging you are describing sounds like carbon brushes.
Even if you are not the original owner, Kirby will do a rebuild for a charge. You can contact Kirby Rebuild department for a quote. It will be money well spent. Kirbys are heirloom quality machines that will provide you with years of faithful service.
