heja
Oops, I meant American FRONTLOADING machines....I did not mean toploading machines, of course they are obsolete and outdated.
My machine brand is Frigidaire, made and owned by Electrolux. I believe the machine is made in USA by a factory owned by Electrolux. It is front loading and spins at about 1000 rpm. Laundry comes out very clean...and DRY. However, it is larger than a European sized machine, 70 cm wide and too high to fit under a kitchen counter. The larger size generates more centrifugal force, so 1000 rpm on a big machine dries like 1400 rpm on a smaller machine.
Here is a list of their products
The prices you see listed are the "suggested price" but usually you can buy them for $150-200 less if you shop at a discount store like
www.bestbuy.com or
www.lowes.com
I believe Electrolux bought the Frigidaire brand so it could market its machines with a name very familiar in USA. When people see the name Electrolux, they think "vacuum cleaners", because no other products with the name Electrolux were sold in USA for many years. People had been buying Frigidaire washers for many years, but of course they were the old fashioned topload design.
One other difference between US and European frontloading washers: US machines fill from both cold and hot water lines. The heater on US machines is not used unless you select a temperature higher than what comes out of the hot water line (about 60-65 C or 140 F). If you select a temperature in the range of 30-60 C, the water enters the machine at the proper temperature, because it mixes water from both lines, and the machine beings to wash immediately. As a result, many machines can wash a load in 60 minutes or less.
If you select a higher temperature, then the heater must heat the water first to the correct temperature, and this can add 30-60 minutes extra to the wash time....US washers usually run on 120 V electricity, so there is not as much power flowing into the machine compared to Europe. When a high temperature is selected, the cycle can last two hours or more, more or less similar to European wash times.
Some of the more basic models do NOT have a heater, which is ok if you do not plan to wash at higher than 65 C. My washer does not have a heater and it works fine, but then it sits next to the house water heater and there is plenty of hot water available one meter away.
The models without heater cost several hundred dollars less than the heater models. Of course they would not work in a European setting with only a cold water line supply, but they do work here as long as you can live with having 65 C as the maximum wash temperature. All laundry areas in all homes less than 50 years old in US will include a laundry area with both hot and cold water lines. I enjoy the shorter wash times, because the machine does not have to heat the water, and when I wash clothes in Europe the two hour cycle times always drive me nuts.
PS some people in US will use European cold water fill washers (usually with 240 V service) in areas that were not originally meant to be laundry areas. For example, I know someone in New York City in an apartment who ran a cold water line into a large double closet and installed a Miele European sized machine. The apartment was built without a laundry area, the laundry room was in the basement and this person became tired of always having to go to the basement in an elevator to wash clothes.
