Leaking Oil Tanks Are a Huge Pain
At least in NYS.
Persons have been sued and or forced to pay for cleaing up/damages from old buried oil tanks they didn't even know were on the property.
In many cases the heating was converted to natural gas,but whomever owned the home at the time didn't bother to remove the tank. So it just sits there and if it rots/leaks there are going to be problems. Long Island for instance gets much of it's tap water from ground water sources, once those wells are found to be contaminated, a track back to the source begins. If it turns out the underground tank on your property is leaking, you are in big trouble.
Consumer groups now advise persons shopping for homes, to inquire about old heating oil tanks. Even if the house is now heated with gas or has an above ground tank.
At least in NYS.
