Back in Service!
jetcone
May 2, 2001
7,678
Schenectady-Home of Calrods,Monitor Tops,Toroid Tr
I inherited a beautiful looking 1956 Bendix Duomatic from Gregm awhile back.
It was the very LAST Duomatic that would carry just the Bendix name.
It looked great and I thought it would be a quick restore -Boom Boom Done and back into service- boy was I wrong.
This machine couldn't have been farther from the truth!
Its taken two years and EVERY system had to be rebuilt, every gasket replaced- even the diaphragm on the pump. I've never had to do one of those in a Bendix before.Its a completely new machine from stem to stern.
I usually don't have to get that detailed but this machine was heavily used. You'll see.
Pictures to follow.
First off when Jeff and I examined her
two years ago we found the mechanism was locked up. We figured a dime or quarter had gotten into the pump somehow, couldn't even turn the motor shaft after unhooking the drive belt!
Well I got into it and found the pump was seized alright but not by a dime! The last load done must have been work clothes with cement.
I found the pump bound with almost 2 inches of cement in front and behind the impeller! I had to chip it all away to get the impeller out.
You can see the cement line in the photo:
Next
I find that the timer is barely advancing. Upon inspection the factory had tightened the chain sprocket so tight that the escapement gear had actually worn down and wasnt' driving the mechanism anymore. (See pix below several panes)
After trying to switch drive gears I gave up! But Larry actually found a timer , it was from a '55 but it fit so in it went!
Try swapping out 19 wires between timers!!
I'm still gonna repair the original timer, John thinks he may have the part in the vast storage facility known as THE MUSEUM. I'll see the gang in a couple weeks.[this post was last edited: 10/15/2012-02:26]
Wow!
A nice looking machine and congratulations on getting it working. I didn't know washer dryers had been around so long. It has suspension too, I had heard that some early front loaders had to be bolted to the floor.
Bendixxii
"Duomatic Central" looking great in the basement Jon, fun to see the insides of the working machine, the drum looks one sturdy piece of metal, What capacity would this be??, looks like it could match a true 8kg drum here.
On the outer drum there are only two outlets, top for powder and bottom for drain, so does the condenser system come off the backplate??
Tested with Rosalies I hope??
What memories you brought back . . .
. . . and how fascinating to see the inside of this Bendix Duomatic!!!
When I was 12, I knew three families that had this model Duomatic and I was able to use it and sit in front of it to watch each and every turn of the tub. They were workhorses.
Thank you for saving this one and thank you for sharing your adventure.
I currently have a Philco/Bendix Duomatic that I believe to be a 1959. It works like a charm. I'd sure love to see your collection in person.
Thanks again.
Jerry Gay
Jerry its been ages!
Come on up any time. Start planning now. You knew THREE families with the same machine?? Holy Moly!!!
Mike- The drum is huge, easily 8 kgs with room to move. But it won't dry the clothes wrinkle free. 4.5-5.5 Kgs for wash and dry.
Fido, yes this is late in the game, Bendix introduced the worlds' first in 1951. Same design as this machine, Greg & JohnE have one. John L's is later I think.
