AEG
Hi Brendon, can you take another picture further back or wider , I cant work out what the carrier looks like, so yours has the door filter, then a another fine filter and then the black sponge pad?
Is it me or does there appear to be more FINE POWDER RESIDUE with the heat pump dryers, or does a normal condenser somehow keep it in the water etc??
Or does the heat pump do such a good job of getting rid of all the moisture that its seperating the fine powder from the water??
Thinking about it even when the loads are dry in a condenser, the workings of the dryer are still moist or wet whereas the Heat Pump dryers appear not to be so!!
