reversomatic
Interesting
Hi Mike and all,yes if the user did not exac
tly line up the programe dial with the the programe number it would not work correctly .If you look at timer chart, link kindly supplied by Tom. it shows prefill only occurs on cam positioins 3,25,43. So one cam position would make a difference ,but the only people that would notice is people like us.Wash times were just influenced by water temprature,there is a holding solenoid in the timer which locks the timer from advancing untill selected water temprature is reached,higher the temprature longer the wash.Hi Paul, would like to see any info you have on the AEG Bella 1002 washer as im still learning about the the way it works.Very powerful bit of kit ,can cope with a load from a standing start to a 1000rpm spin.It draws over 1000watts on spin,none of this fancy load balancing stuff.Anyway keep on washing Regards Nige.
