Bendix automatic Home Washer MODEL D (511)
Evening all
Spent some time checking out this earth fault, odd readings all over the place, very confusing indeed.
So, something is amiss but what?
I decided to check each electrical item individual one at a time disconnecting it completely from the wiring harness, everything checks out for continuity of the windings and nothing is going to earth, rechecked the reading on the plug and no earth fault, so I have disturbed something along the way, maybe Mr Mouse has nibbled a wire that I can’t see.
Whilst on my hands and knees probing with the meter I found those elusive thermostats in the wiring diagram on the right hand side of the tub hiding under the very large tub seam, the plate holding the assembly looks like it could house a heating element, but blanking rods are installed in those holes.
I’m still a little bewildered as to there function, the machine dose not have a heater, very intriguing, I wonder what the temperature setting is.
Also while crawling around on the floor I worked by hand the drain valve which was stuck, after a few movements back and forth the valve freed nicely, let’s hope she is water tight!!
Tomorrow I will test the machine with the PAT tester and if a satisfactory result is achieved I will then bite the bullet and show the old lady some mains, I’m not normally so careful dam right reckless normally and just plug in and see the bang but being such an old girl and with electrical parts that are nearly impossible to get replacements it’s better to take care and not damage anything unduly if I can help it.
Lee
