Bendix automatic Home Washer MODEL D (511)
While in tumbling mode I measured the drum speed with the tachometer. 59.0 rpm
Strange see the back of the drum whizzing past though the soap hole, the water seems to stick to the outside very odd..
I let the machine run till the first drain and interim spin, nothing leaking out of the bearings.
Measured the spin speed 406.9 rpm
The hot valve opened partly only allowing a small flow of water and then stuck in that position and would not stop.
I tried the cold valve but this one is completely closed and nothing flowed.
The signs of very hard water is present in both valves and the two original hoses.
So this is the next step, strip down the valves and clean out the scale.
Hi Mike
Is the water solenoids in you stash complete valves (brass fittings ) or just the electrical coils which are mounted on top of the brass fittings.
Thanks Lee
Better than soap on TV
Lee this is just brilliant mate step by step you are getting there, who cares if you mums Niagara falls water feature doesn't work any more! great thinking on using the pipe.
Those valves should come through but if Mikes are complete yeah why not change them, I am loving this thread it is along time since we had such an interesting restoration going on.
Great stuff
thanks
Gary
Hi Mike
It’s nice to now that the top electrical part came separately as a spare part, I’m sure both coils are working and will strip the unit down when I find time I’m sure it’s the scale jamming them up and maybe the rubber parts have all perished, I’m also working an a Bush consol TV from the same vintage year of 1957 which is coming along well too.
bendix
Congratulation lee on the continued good work. For hoses it might be worth try car heater hose which you can buy by the metre in Halfords. I have used this successfully on a HM 3334. Its a bit more flexible than garden hose so if its a bit tight soaking the end in hot water may make it a bot more flexible. You might also find lubricating whatever you might be putting it into with a little bit of washing up liquid too.
good luck
Al
The cold fill
Hi lee you probably know this but are you sure the cold fill valve is faulty. It will only kick in in warm wash when enough hot water had been used to kick the thermostat in. Also rinses are likely to be warm and the same will apply there. That's how the lt works so it may be the same it might be worth trying hot water to see if cold water one works at same time.
I could be wrong though as only going on what I know about my bendix. My model d is still sitting in garage
Richard
Excellent thread Lee. Lovely machine and really interesting to see the progress with its restoration. Nowt wrong with finding modern ways around getting the machine water tight and seeing how you get around problems is great.
2nd bout of exclamation for today now ....
MY GOD, MIKE! That is one hell of a spares find. Lovely to see all the parts with their individual boxes - each one a little piece of art. Much akin to having a matchbox car still in its original box.
To think that 'pieces' like that have been chucked out of shops over the last 30 years, straight into landfill.
Paul
How’s it going chaps?
Richard you right with the cold valve, as I see it on the hot wash setting only the hot valve is energized, while on a warm wash the stats play a part, filling starts with hot only when the temperature triggers the contacts the cold valve becomes energized for mixed fill.
I think its mixed fill on rinsing but until she’s running properly I can’t say for definite.
Onto today’s tinkering.
Firstly some oil for the drive unit, I tried to remove the drain plug from the bottom but couldn’t shift it at all.
I then tried the smaller one to the left, again it would not shift and the square top part started twisting so no chance of removing that one.
