slowspinspeed
- Joined
- Oct 27, 2007
- Messages
- 2
I'm new to this type of website but i could really benifit from a little help .I have had this old Bendix for a few years and have had a do a bit of refurb bearings ,seals, hoses ect. It stands in my kitchen and is bolted down.The problem is i cann't get a valve seal for the pump .The part that's needed provides a seat for the mushroom valve to sit on .When you turn the dial to drain the bowden cable pulls the mushroom valve away from the seal and water then water flows into the pump and then into the sink.At present i have to put a bung in the drain hose to stop it constantly draining the tub. I have made a couple of seals but they never really work.I wonder if one of the chaps in the States will be able to help.I will try and put a few more pics on if anyone is interested.The machine is a really fab little piece of 1950s engineering and thanks to Mike King i have managed to find out more about how to look after it thanks to his help and knowledge.
