Big Window Hamilton Dryer in St. Louis
Tumbler, best of luck with your new washer and dryer, and thanks for having the presence of thought to offer your Hamilton to collectors. :-)
Hamilton Gas dryer
My family purchased a Hamilton Gas clothes dryer in 1968. It's the same dryer from the control console down as the one in the picture. My dad purchased it from the propane gas company where he worked. My Mom dryed clothes for 7 people in it for about 8 years. The dryer however was prone to problems. Mainly the ignitor used to ignite the flame on the burner. Glow bar technology was not out at the time. The sparker was constanly breaking. Our's had the Sun-E-Day light in it also. My mom use to tell me I would go blind looking at it because all I would do was sit and watch the clothes tumble in the window. My parents didn't understand my fascination with appliances. She later replaced it with a Maytag gas dryer in 1976 which she used for 26 years. Sadly there went my BIG window dryer as Maytag's does not have a window.
oh steve
ha ha ... youll like it.. just got it into the garage and cleand it up a bit then just had to plug it in..super quiet and to fun to watch.. the door glass is even tinted to protect you from all those mean nasty old ultra-violet rays.. i threw in a bunch of white towels so i could watch it run..its cool the drum lights up from the back with a white light and the cloths tumble under the glow of a really cool purple light from the front of the drum.. its really fun to watch.
Chris------
Oh wow! How "Timothy Leary"----- a dryer with purple lights! Can't wait to put it into service now. Thank you sooo much for being so nice going to get her and cleaning her up for me. You are such a kind person.
well
thats what its all about..helping each other with finds..and finding that dream machine..so greg and terry dont forget about dinner come june
Some Hamilton features
My old Hamilton-the one Steve's picking up-has a drum light and the Sun-E-Day light (the 40-watt drum light serves as the ballast coil for the Sun-e-Day, which is actually a small, 4-watt mercury vapor lamp). The lights are on during the entire cycle, no provision for disabling them. However, anyone with enough electrical knowledge to restore old appliances can install a simple switch in the circuit. The lights also come on when the door is opened. This model has NO console light. The motor is made by Emerson, and is what I call an "old style" motor in that it looks like a real motor-not the skeleton-frame rubbish they began using in the 70's, which use non-replaceable steel bearings and are epoxied or tack-welded together. These old motors can be opened up, the wool-yarn packing around the bearings re-saturated with oil, or if necessary the bronze bearings can be pressed out of the end frames and replaced (just be sure to ream them before reassembling the motor). The motor in this dryer should be good for considerable more service if one takes the trouble to re-oil the packing. Note-don't overdo it, or oil will get into the starting switch contacts and cause all kinds of grief. A teaspoon or so per bearing should be plenty. Then put a drop of oil on each shaft bearing when you reassemble it.
More on Sun-E-Day
Steve: Note that the drum light and Sun-e-Day light are connected in series; if one burns out, neither will light. Both were working as of when the drier was turned over to Chris. I think I have an extra Sun-E-Day bulb (they haven't been made for years-they're probably known to the Peoples Republic of California to cause cancer of the fingernails or something). When I get back to St. Louis, I'll look around my shop for it. If I find it, it's yours!
I house-sat 20 years ago for someone with a small-door Hamilton dryer which probably was from about this vintage--gas, with the standing pilot accessed from a lid on the top. Weird lint filter along the floor--I remember pulling it out too far and having a devil of a time getting it back in the tracks. Lint filter was also strange material (perforated sheet metal rather than screening)
JL
standing pilot
Jamiel: the Hamilton you are referring to is much older than the one Steve got from me; mine (Steve's now) uses a "buzzer-type" electric ignitor which produces sparks from vibrating electric contacts and sounds a bit like an old alarm clock. Steve: the one time I had a problem with the dryer was a failure to light; the screws holding the ignitor assembly together got loose. I removed the ignitor and tightened the screws and re-installed it: problem solved. It probably won't give you any trouble.
