Bob Load Hobart style
top spray arm
My church has 3 of these Hobart's but none of them have a spray arm on the top, just the bottom one. I guess they're older. When they're used the plates are rinsed off and the silverware has been soaking. They also use the original Cascade (with bleach--a particularly terrific "smell memory" for me. You can buy the original cascade from Sysco Food Services.
Courtney
Actually, pumps don't atrophy and the soft food disposer does not die from lack of fiber when dishes are rinsed before going into the dw. The main thing that happens when dishes are hand rinsed to the point of almost being clean before being loaded into the dw is that unless only a small amount of detergent is used, the caustic components of the detergent have no organic matter to work on and no grease to emulsify so they go to work on the dishwasher parts. Any vinyl or rubber-like components like rack coatings, seals and gaskets have the essential oils in them pulled out by the rich detergent solution leading to the racks rusting when the vinyl covering them is damaged, leaks developing when seals and gaskets turn hard, split or get eaten away, often allowing water to leak into the motor, and ruin the bearings or short out the windings. Water can wind up other places like in between the inner and outer door panels when the gasket around the detergent dispenser allows leaking. Sometimes the water can leak onto electrical components like the terminals on the dispenser or in a vulnerable place like where the wiring harness passes from beneath the door to the components beneath the tank. This is the place that the wires have to flex each time the door is opened or closed. If the insulation of the wires or the plastic guard that is supposed to surround the harness at this location gets brittle from leaking caustic detergent solution, the wires can short against each other or the frame. When this happens, the resulting short can burn a hole through the door's aluminum front panel before the circuit breaker trips, unless the breaker is rated for too high for the usual 15 amp dw circuit, in which case you can have a fire. Dishes should either be rinsed in the machine using Rinse & Hold or if they are throughly rinsed because it takes a week to accumulate enough dishes to wash, use the minimum amount of detergent in the main wash only.
replies
C'Villewasherbo, 3 of them?? COOL! I had an older one as well it only had one on the bottom. They are like the really older kitchenaids, When Kitchenaid/Hobart changed the pump and body is when this model came out with the wash arm on top and the Kitchenaids before Whirlpool had the wash arm for the top rack. Think those older older ones use about 4 1/2 gallons of water per rack, this model uses less becuase it uses the rinse water for the next wash. Frigilux, I always hated washing pasty bags too and had always wished I had something like those to put them in the dishwasher. I was ordering some extra racks for a dehydrator from Nesco and they had those on closeout really cheap, just a few bucks a piece so I got 10 of them. They are for those american harvest cenvection ovens. Only thing, don't let the bags stay on too longs after they are washed becuase they can leave rust spots from the joints where the wires are connected.
