earthling177
I am very curious about the F&P.
I have two questions at this time.
One is how did you install the machines? Can one get away with just the two screws against the countertop like most other dishwashers do, or does one need to fasten it by the sides of the cabinets? What are the advantages and disadvantages between the screws on the side of the cabinet (front of the dishwasher) vs. screws inside the cabinet (by removing the drawer and screwing from the inside)?
The second question is perhaps a bit weirder. I remember when the DishDrawers came out about 20 years ago, there were several TV reporters (so, not the best, most reliable sources to begin with) claiming that one of the advantages of the DishDrawers was that one could customize the machines -- for example, one could run one drawer as a "half-load" machine and always have clean dishes, or one could run each drawer with a different cycle and they implied that one could remove all the inserts from the rack and rearrange them, so, for example, one could reconfigure one drawer to have both glasses inserts and one drawer to have both plates inserts, and run one drawer in the China cycle while the other one runs a Normal or Heavy Duty cycle. So, was this possible, is this still possible, or have they changed the racks so one always needs to have a glass and a plates insert in the same drawer? I'm asking because if it still works (or has ever worked) out like they described 20 years ago, maybe Steve could just put the two glass inserts in one drawer and the two plates inserts in another and make it into what most dishwashers have for a racking system.
Thanks in advance,
-- Paulo.
Thanks in advance,
-- Paulo.
