We have a Bosch Side-by-Side US-Style Fridge-freezer. It suddenly started tripping the RCD (GFCI) yesterday and I couldn't figure out what was going on.
We cleared it out, vacuum cleaned the condensor coil (it was full of dust) and generally gave it a good cleaning out inside and allowed it to defrost over night.
I turned it back on again today and after about 2 or 3 mins it tripped the RCD again.
So, I decided to open the back panel of the freezer and take a look at the evaporator etc to see if anything was going on.
The entire area was soaking wet, including all the foam seals. There was a large bag of some kind of insulating paste sitting directly ontop of the evaporator! It looked like it had been left in there when the machine was built 8 years ago!
Blobs of this had broken off and worked their way into the drain pan below clogging the drain line.
I used a curtain wire to rod out the drain line and gently dried out the entire area.
Fingers crossed it now works OK.
It hasn't tripped anything since it's been restarted.
Has anyone else ever come across anything like this before?
It appears to be a re-badged 230V 50Hz version of a kelvinator side-by-side. It's made in the USA and has very little to do with Bosch I suspect.
Also, where would the evap drain water have gone if the tube was 100% blocked?!
It's a bit of a mystery !!
Overall, I am very unimpressed with this fridge, it was extremely expensive and it's just really badly built. Bits have fallen off e.g. the covers for the door hinges, various shelves etc.
The 3 drawers all broke and had to be replaced!
In general I'd avoid like the plague in future and stick with something designed a little closer to home.
