That is a Monitor washer from the 50's to 60's. Has an impeller on the back of the tub and laundry goes round and round. We had one here in the 60's, had a gravity drain and hand crank wringer that folded up inside.
since it has the impeller against the back of the tub, it was exactly like the hoover twin tub washing. but instead of having the spinner, you had to work the manual wringer.
I have three or four different models of the Monitor washer in my collection, including the one with the electric wringer. They are definitely cute little machines.
Monitors were generally advertised in the small, one column ads common to the back pages of women's and shelter mags. Using one was like using a wringer washer which was the standard of laundry automation then. The small size meant that apartment dwellers could have a washing machine. The small sizes were probably mostly used for "personal wash."
Yes, thats it Phil. Ours was very similar but did have a drain hose and did not have a switch to turn it off and on. They should have filled it with water and some type of laundry to show how it really works instead of spashing all the water out the top.
