California Electricity Dilemma
EVs make a lot of sense when you consider the power generated to charge them can either be nuclear, or a thermal plant with a carbon capture system on it. Thats true net zero. That makes total sense to me and I totally applaud and want that idea. That would remove a significant amount of GHGs. But we need to weigh the environmental costs of mining and how to make those cleaner. Google the Giant Mine in Canada. Its the mining playbook to extract ever last ounce of ore and then go bankrupt leaving the reclamation to the taxpayer. Thanks!
We are a wasteful society, driven by whats new and hot. Things were disposable before, but now its on another level. Social media alone accounts for roughly 10% of energy consumption. If were as doomed as we are regarding the climate, its time to shut that shit down and prioritize what we need to live, and Instagram aint part of that. But we won't do that. We're not going to do a f*cking thing about climate change because it will interrupt and cause too much sacrifice to our lives.
Modern appliances, not lasting as long
There is no evidence that replacing a washing machine every 10 or 12 years instead of every 20 is wasting any energy.
Look at the facts a new washing machine uses 1/3 the amount of energy and hot water as the older one.
It takes 1/5 the energy to manufacture a new washing machine so you’d have to throw away five of them to equal one old Maytag.
Appliances are not sent to the landfill. They are shredded and ground up and the metal and recyclable materials are reused, it’s still a wasteful process however, but new machines are just so much more efficient in the manufacturing of them.
The new washing machine only has 1/4 of the copper in it as an older one, it only has about 50 pounds of steel in it compared to older machines that had three times that much or more.
And the efficiencies in manufacturing, and the fact that the plants have to run without producing much pollution, make them far more efficient to build.
Older machines had a lot of energy wasted repairing them because of all the trips the repair guy had to make to the home to repair them. Where is new machines? Many of them won’t even be repaired once.
I documented one Maytag a 900 that had 40 repairs on it, yes it lasted 50 years but you couldn’t begin to calculate the amount of energy that machine used in the amount of money that was spent and time fixing it. It would’ve been better just to have used five modern washing machines and recycle them.
John
Electricity
I am all for green energy, however it will not be feasible to require a quick mandate like California. I do foresee issues with the power grids and costs to build new infrastructure that the increase in demand will require. I am a big fan of nuclear energy, though it has a rather bad taste left in America's mouths like mentioned prior.
Personally, I plan on building a home with quite a bit of solar power, geothermal HVAC, and killer insulation, but the costs for myself will never be recuperated. For the average homeowner, it just isn't possible.
The blunt truth being energy efficiency isn't safe, economical or practical. All the cost allocated in expensive equipment on the end users side x 300 million can build hundreds of nuclear generating stations.
It is much simpler, cheaper and better for the environment for a furnace to contain nichrome coils, a few thermal cut offs and a sequencer driven by a carbon free nuclear than it is to have ground source heat pumps driven by natural gas pants.
Compressors doing double duty last 15-20 years at most, solar panel output drops sharply with time; while coils can be built to last indefinitely at a fraction of the cost. No leaks or complex inverters to fail. In comparison nuclear reactors, steam turbines and generators last 60-80 years at minimum.
All of this love for nukes and claims about efficiency and net zero yadda yadda yadda ignores the Macy's Parade size elephant in this room known as planet earth:  Deadly, practically eternal radioactive waste that has to be transported and stored for periods longer than the human race will still be around before its lethal properties have dissipated.  That alone is reason enough to abandon nukes -- yesterday.
@chetlaham "All you've got is water, steam and metal. Not much to wear out or age in comparison."
Uhh... ahhahaah... hmm... There is a lot to unpack there. Thats a big no from me, dog.
Its not just water, steam, and metal, and thats not "not much to wear out". Power plants, regardless if its thermal or nuclear, are extremely expensive and complex machines to operate that most certainly do wear out. The cost to operate a nuke plant is an order of a magnitude or two more than a thermal plant because of the fact that fear based regulations make it almost impossible to do anything in them.
I would not place much stock in that life extension link you've provided. Just because a utility gets approval to extend the life of a plant for twenty more years does not mean they are going to run it for that long. There is going to be a point too when parts for equipment are no longer available and no one knows how to make them cheaply. There is going to be a point too when some component wears out entirely and needs complete replacing, say the reactor vessels wall thickness reaches its end of life limit... Now what? Are you going to make a new one LOL? Who is going to pay for that cost? Consider too that the decomissioning process of a nuke plant also requires an operating license which, that process could very well fall in to the twenty year life extension.
Its not just water, steam, and steal, and it certainly is a lot to wear out. The steam turbine alone, which both thermal and nuke plants use, is an extremely expensive machine to maintain that requires an assload of maintenance when the plant goes in to a maintenance outage every few years. There are so so so so many components in any plant that wear out at various lengths of time, be it months, years, or decades. Thats a nutty statement to make.
Nuclear waste is a real problem, but we have to pick which problem we want to live with. Theres no such thing as a free lunch, so you have to pick one: nuclear waste which emits no GHGs but its poisonous if not properly stored? Or GHGs that are accelerating the death of the planet right now?
Which is all peanuts in comparison to the overall longevity and the large number of components that do not need replacement or those that require relatively cheap overhauls.
Also, explain how a coal plant is simpler than a nuclear plant? The absence is pulverizes and scrubbers is a good start.
New machines versus old. i.e. plastic versus metal. There is much more plastic in newer machines in their tubs, etc. Plastic takes oils to manufacture. I rather keep an old metal machine going that uses more water and power. Recycling also uses energy to accomplish, lots of it. From processing it to moving it around the yard with cranes etc, to hauling it to barges bound for China. The other thing about all this pollution talk is no one is getting on the band wagon about how countries half way around the world are polluting like crazy and getting away with it. Its time to go after them and give us a break. Go back 50 years here and see the waste and pollution compared to now, its changed for the better dramatically. Over in Asia or Russia etc? If anything its gotten worse 10 fold with their booming economies now that countries source cheap products from there now.
If you all want nuclear energy plants in your states or near your homes, be my guest. But as long as I draw breath and live in California I say hell to the no on nuclear energy plants in California! It only takes ONE disaster in a nuclear energy plant, usually due to human carelessness and you can’t get that genie back into the bottle. Not to mention what are ya gonna do with all that nuclear waste? Poison the earth and the oceans disposing of it?
I agree with Ralph and John about nuclear energy and it’s no bueno!
Everyones so worried about whats gonna happen in 2030 in California when the new laws take effect banning the sale of new gas appliances and autos with internal combustion engines. I haven’t read the law, but I would imagine that those that already have gas furnaces, water heaters and stoves will be able to continue to repair them, and maybe those homes may be grandfathered in and allowed to replace these appliances with new gas appliances should they be beyond repair. But they’d need to buy them from an out of state dealer.
Its the NEW construction that they are going after in the prohibition of gas appliances.
There are plenty of problems more important that this, cross that bridge when you come to it.
If we don’t do something to stop Climate Change we won’t even have an earth thats inhabitable by mankind anymore.
Be part of the solution not part of the problem.
Eddie
@chetlaham "Which is all peanuts in comparison to the overall longevity and the large number of components that do not need replacement or those that require relatively cheap overhauls."
As I have stated, any maintenance or contract work in a nuke plant is a magnitude greater than that of a thermal plant purely because of the regulatory requirement of a nuke facility over a thermal one. I dont think you have any clue the level of maintenance, or the costs, for a power plant of any kind. None of it is "cheap". Its huge huge huge work. A thermal plant planned outage can last 6+ weeks for a 250MW unit. Thats not "cheap".
"Also, explain how a coal plant is simpler than a nuclear plant? The absence is pulverizes and scrubbers is a good start."
I can't believe I am going to get in to an argument with someone who claims nuclear plants are simpler than a coal fired one. Especially considering you think you've "got me" by mentioning the fuel handling and emissions controls systems... But here we go.
In terms of knowledge industry wide, thermal generation has an abundance. Nuclear knowledge is few and far between, and expensive.
The number of people who can fix a thermal plant is a lot greater than that of a nuke one. The ones who can fix a nuke plant aren't cheap.
Water treatment requirements of a nuclear plant significantly overshadow that of a thermal facility. In a closed loop PWR, the reactor coolant requires expensive chemicals that are not effected by the fission process. The fission reaction can create undesirable water chemistry such as excess O2, so excess hydrogen must be maintained. Reactor loops require the use of a high purity stainless as fission, again, can pull impurities out of the stainless.
Chemists for water treatment in a thermal plant are easy to find. Chemists for nuclear are not, and when you do theyre expensive.
There is only one water loop to control the chemistry for at a thermal plant. In a nuke facility, there is at least three. All requiring their own unique chemicals that are impervious to the effects of fission.
There containment building for the reactor is complex.
There are only a handful or people who can operate these reactors, with the cert process being five times as long as the one required for a thermal plant.
Spent fuel pools and the spent fuel system is an art form. It must be monitored, cooled, and maintained.
Every single nuke worker is monitored health wise multiple times a year. Blood work, scans, check ups. Dosimeters worn at all times. Exposure limits tracked.
The emergency preparedness and emergency scenarios are probably twice that of my refinery. And refineries are pretty toxic, deadly, and explosive neighbours.
There are environmental and radiation monitoring systems at various radius distances away from nuke plants which thermal plants do not have.
The controls system for a reactor is about three times as complex. In a thermal plant, MW output is cascaded by loading the generator, which loads the turbine, which lowers the water level and pressure in the steam drum, which increases feedwater flow and increases firing rate, which increases fuel flow, which speeds up the pulverizers. For a reactor, MW output is cascaded by loading the generator, which loads the turbine, which loads the steam generating loop, which loads the steam generators, which lowers the water level and pressure of the SGs, which increases the pump loop speed of the SG, which increases water flow to the SG, which causes the pressurizer in the reactor to drop press, which causes the heat load in the reactor side of the SG to drop, which causes the reactor coolant pumps to speed up, which causes the reactor temp and pressure to drop, which causes the control rods to be manipulated. Nuke plants have almost three times the cascading control systems.
A nuke plants turbine is mostly that of a low pressure (LP) style, which requires a lot more care to make sure the steam entering the turbine is still superheated and absent of wetness. LP turbines by nature are way easier to make saturated steam due to the rapid pressure drop.
Nuke plants typically have, at the 1000MW unit mark, three to four LP sections, which means three to four times the steam controls compared to a thermal plant since a thermal unit has one steam inlet control system for the whole turbine.
The Safety Instrumented System, or SIS, that independently oversees the operation of any plant, is way more complex in a nuke plant. For a thermal plant, the SIS just has to trip the fire and thats it. Runaway states in thermal plants are easily controlled and very rare. By design, a runaway condition is next to impossible. Once the steam valve shuts on the boiler and the fire is off, the problem is over. However, in a nuke plant, the SIS has to monitor three times as many control parameters, and not only that, still has to control once it causes a trip. Even in a tripped state, a reactor can still runaway, and the SIS system has to prevent that. A thermal plant is either on or off. A nuclear plant has multiple laid up states, for example in refining we call one laid up state safe park. The plant isnt off, but it isnt on either. It can still runaway and still blow up. And this state still requires operation, oversight, and intervention. And still has an SIS intervention.
Fuel handling in a nuke plant is either complex, or insane. They either have to go to a reduced rate or be shut down all together to refuel.
Shutting down a nuclear unit to an off state takes weeks. A 250MW thermal plant is less than an hour.
Starting up a nuclear plant takes weeks. A 250MW thermal plant is roughly twelve hours from light off to synced to the grid.
The heat mass in a nuclear reactor, or warming rate, overshadows thermal plants. At roughly 30C an hour heating rate, the amount of pipes and vessels handcuffed to that rate is nothing in a thermal plant, and thats not even taking the turbines heat loading rate in to consideration. This is just the steam generating side.
Nuclear plants also like steady state power demands. Any major change in the demand by either reduction or increase can upset the reactor for hours. They do not like change at all. A thermal plant can meet a demand change within ten minutes.
Shall I continue?
Nuclear plants have been controlled by relay logic
You make the education, accreditation and verification of nuclear workers sound like a bad thing when it has lead to highly competent individuals resulting in the safest energy industry, by far.
Large parts of the containment process are comprised of static and passive assets vs active mechanisms. For example it takes just a few feet of deionized water in a spent fuel pool to bring radiation down to safe levels. Simple boron is used to control the reactor, and concrete does most of the work in the containment dome.
Replication does not mean added complexity in of itself, especially when a nuclear plant is designed essentially as series (or) logic circuit such that the plant is trying to shut itself down but many parts of the system (controlled by operators) must be within range to keep it running.
The dosimeters, radiation detectors, ect are supplementary additions and do not directly control the plant itself. Same goes for the instrumentation- half of it does not anatomically control the reactor- its merely data feedback for the operators.
Regarding load swings, these can be compensated for via operator control, so much so France generates most of its power via nuclear energy without trouble.
My question to you is, have you seen the AC and DC control schematics to a nuclear plant vs a coal plant?
I never said it was a bad thing. Its a good thing. But the level of education and certs required adds to their complexity.
"static and passive assets vs active mechanisms" hahaha what are you talking about?
"Nuclear plants have been controlled by relay logic" No, they're not, and I dont think you know what that means.
"Replication does not mean added complexity in of itself" So if I go from two pumps to eight, that's not more complex?
"especially when a nuclear plant is designed essentially as series (or) logic circuit such that the plant is trying to shut itself down but many parts of the system (controlled by operators) must be within range to keep it running." I dont even know what you're trying to say here.
"The dosimeters, radiation detectors, ect are supplementary additions and do not directly control the plant itself." Certain rad detectors have the ability to trip the facility. Supplementary or not, these things increase the complexity of the overall facility.
"Same goes for the instrumentation- half of it does not anatomically control the reactor- its merely data feedback for the operators." I don't think you understand controls in an industrial setting. Whats an anatomic control? Never heard of that.
"Regarding load swings, these can be compensated for via operator control, so much so France generates most of its power via nuclear energy without trouble." No, they cannot. Why would operators intervene when the facility is in automatic? The controls are designed to run the facility in auto. I would not want to work in any power plant that requires me to intervene any time the demand changes noticeably. That would make for a very dangerous plant. And how do you know France doesn't have trouble? It's also not "trouble" demand swings are part of the normal operating cadence. Have you been in one of their nuclear facilities at 5am to 9am, and 4pm to 8pm? Have you been in any power plant at those times? Do you have any idea why I mentioned those times?
"My question to you is, have you seen the AC and DC control schematics to a nuclear plant vs a coal plant?" What the hell is a AC and DC control schematics in reference to a power plant? I've never heard of that before.
Listen, I've worked one year in thermal power generation and ten years in refining where we generate our own power through thermal and sell it to the grid and I don't think you know what you're talking about. I think you're just throwing words together to sound like you know what you're talking about.
[this post was last edited: 11/26/2022-16:40]
Also, there is nothing wrong with decay heat, or the thermal mass of a reactor in normal start up or shut down- on the contrary you want a gradual heating in a reactor. These are all taken into account and dealt with accordingly by the operators.
Refueling isn't an issue either when it is done in intervals spanning years. A coal plant needs to be refueled continuously, in real time.
I said this in an earlier reply. Thanks for using it to prove my point because a nuclear unit takes days to start up versus hours for coal. Days because the system is significantly more complex because it has significantly more parts than coal.
A coal fired plant does not need to be slowed or shut down for refueling. A nuke plant does. This downtime is time not generating revenue.  Refueling operations are big big jobs for reactors.
