Calling Combo52, timer block repair
Chetlaham
Mar 11, 2013
4,515
United States
I know you are an expert in repairing countless machines, something I lack. Please forgive me if obvious, but do I need a special tool when crimping these? And how do you go about doing it (properly) lol?
http://www.repairclinic.com/PartDetail/GE-Dishwasher-Terminal/WD1X1434D/270250?ss=a9b3c57&mr=0
I plan on crimping them to new wire and inserting them in one of these:
http://www.repairclinic.com/PartDetail/GE-Dishwasher-Terminal-Block/WD1X1432/270247?ss=a9b3c57&mr=0
Looks simple enough but Im also kind of puzzled.
Hi Robert
The terminals you've linked to are what's known as "open barrel," and they do require a different type of crimper than the more common insulated type. You can see what they look like in the attached pictures lifted from the link provided. The tool shown is a dual crimp type, meaning it will make both crimps simultaneously (one crimp into the wire and one into the insulation), but cheaper single crimp tools are also available. As for the dual crimpers, you can find them at any number of on line vendors and prices can vary greatly, so a used pair off of eBay may be a better bet.
http://www.cycleterminal.com/crimp-tools.html
Bruce - LOL - The only reason I know anything about this is that I went through this myself a while back. I was looking for a crimper and terminals that would produce a crimp exactly like the ones found on the original wiring harnesses of my machines and this is what I came up with. I'm a bit of a stickler for details and like things to look original after a repair.
Robert - Yes, those are the type of tool you're looking for, but the one review that particular pair of crimpers received mentions a troublesome gap between the two ends of the crimping die. He does say with some extra care a good crimp can still be made, but according to him it's also easy to destroy the terminal with them instead, so be careful. Good price though if they work. I paid far more for mine off the Snap-On truck.
That's a pretty useful guide. And if you look at the crimpers used in it you can see there's a small gap between the two halves of the forming die that don't seem to cause the user any trouble. So with any luck you should have everything you need. I hope it all works out for you.
Thanks!
The HD crimpers have an adjustment screw, so if worse comes to worse I can play with that to get the right outcome. I will buy at least a ton of those terminals to practice with before actually trying it out on the machine.
Removal tool
I saw a removal tool for molex connectors and was wondering if such a creature existed for appliance timer blocks. That way I can removed the terminals from the older timer block and re-use the existing. If anything it will be a lot easier to do it that way rather then cutting off the old block and redoing all the terminals.
