DADoES Well-known member Platinum Member Joined May 21, 2001 Messages 15,801 Location TX, U.S. of A. Sep 11, 2011 #2 "Before" pics were requested, so here be a bunch of 'em.
DADoES Well-known member Platinum Member Joined May 21, 2001 Messages 15,801 Location TX, U.S. of A. Sep 11, 2011 #3
DADoES Well-known member Platinum Member Joined May 21, 2001 Messages 15,801 Location TX, U.S. of A. Sep 11, 2011 #4
DADoES Well-known member Platinum Member Joined May 21, 2001 Messages 15,801 Location TX, U.S. of A. Sep 11, 2011 #5
DADoES Well-known member Platinum Member Joined May 21, 2001 Messages 15,801 Location TX, U.S. of A. Sep 11, 2011 #6
DADoES Well-known member Platinum Member Joined May 21, 2001 Messages 15,801 Location TX, U.S. of A. Sep 11, 2011 #7 $0.02 stuck behind the door. And found $0.23 behind the moisture sensor housing on the bulkhead.
DADoES Well-known member Platinum Member Joined May 21, 2001 Messages 15,801 Location TX, U.S. of A. Sep 11, 2011 #8 Typical blue staining from denim dyes.
DADoES Well-known member Platinum Member Joined May 21, 2001 Messages 15,801 Location TX, U.S. of A. Sep 11, 2011 #9
DADoES Well-known member Platinum Member Joined May 21, 2001 Messages 15,801 Location TX, U.S. of A. Sep 11, 2011 #10
DADoES Well-known member Platinum Member Joined May 21, 2001 Messages 15,801 Location TX, U.S. of A. Sep 11, 2011 #11
DADoES Well-known member Platinum Member Joined May 21, 2001 Messages 15,801 Location TX, U.S. of A. Sep 11, 2011 #12 Has the skid-type belt idler ... which of course will be replaced with the replacement pulley-type. Note the sound insulation pad to the right.
DADoES Well-known member Platinum Member Joined May 21, 2001 Messages 15,801 Location TX, U.S. of A. Sep 11, 2011 #13 Found this extra top-locator pin down here, apparently left from the factory. Insulation pad on the left. They're listed at $99 (I assume for the pair) on SearsParts! $85 at PartsTap.
DADoES Well-known member Platinum Member Joined May 21, 2001 Messages 15,801 Location TX, U.S. of A. Sep 11, 2011 #14 Lint-infested motor.
DADoES Well-known member Platinum Member Joined May 21, 2001 Messages 15,801 Location TX, U.S. of A. Sep 11, 2011 #15
DADoES Well-known member Platinum Member Joined May 21, 2001 Messages 15,801 Location TX, U.S. of A. Sep 11, 2011 #16 Blower housing with thermal fuse (white, upper) and thermistor (black, lower).
DADoES Well-known member Platinum Member Joined May 21, 2001 Messages 15,801 Location TX, U.S. of A. Sep 11, 2011 #17 Element connection and high-limit 'stat.
DADoES Well-known member Platinum Member Joined May 21, 2001 Messages 15,801 Location TX, U.S. of A. Sep 11, 2011 #18 Bottom of filter housing. The fuse was initially stuck in the lint higher up at the drum air intake, it fell down when I bumped the housing.
DADoES Well-known member Platinum Member Joined May 21, 2001 Messages 15,801 Location TX, U.S. of A. Sep 11, 2011 #19 Up here is where the fuse was stuck.
DADoES Well-known member Platinum Member Joined May 21, 2001 Messages 15,801 Location TX, U.S. of A. Sep 11, 2011 #20 Back of the air intake on the bulkhead. The foam seal is deteriorated.[this post was last edited: 9/11/2011-21:50]
