fan-of-fans
Do you have a particular ceiling height that you prefer? Or what does your home have?
I have noticed older homes built in the 1940s and earlier tended to have higher ceilings, especially in the southern states. I was told it kept the home cooler as the hot air could rise a considerable distance from the floor. Of course colonial era homes in the north would have low ceilings to keep the warm air lower in the winter.
I notice most homes here from the 1940s onward tend to have 8 foot ceilings. Somewhere around 1965-1975 some houses would have 7 or 7.5 foot ceilings. Not sure if this had to do with the energy crisis or if it was a style choice.
As for higher ceilings, I have seen some 1950s-70s era homes with vaulted ceilings. But I have never really seen a home from that era that had tray ceilings or anything higher than 8 feet. I wonder why that is?
In the later 1980s I guess is when ceilings started getting higher again. Today it's not uncommon for homes to have 9 or 10 foot ceilings. Some houses have different wall heights at the front, such as the entry porch being higher than the rest. I don't recall that happening in houses from before about 1990. Most houses before then had the same wall height all around the house, such as ranch houses. I'm not sure what you call the style with the different wall heights.
As for my favorite ceiling height, I don't care for anything less than 8 feet. I like vaulted ceilings in the main areas because it makes the house seem larger and more open. I also like when the cabinets are open above, instead of those boxed in tops.
