Changing belts on White-Westy SpaceMates Washer.....
randycmaynard
Oct 7, 2009
655
Was wondering if anyone has ever changed belts on a White-Westinghouse SpaceMates front load washer? My machine is the 3 belt version - smaller belt from motor to pulley that has a larger belt runing the potato pully for the wash/rinse tumble and then a large belt around the large pulley for the spin parts of the cycles. The obvious easy change is the spin belt - it's the other two smaller belts that present the challenge. It may be much simpler than it looks to change the two smaller belts but, as you well know, nothing is usually all that simple when working on these vintage machines.
Any/all help appreciated!
