Commercial whirlpool belt drive rebuild
It’s normal to have a lot of side to side play in the agitator shaft when the transmission is out of the washer.
It’s too bad. You’re not closer we still recycle belt drive machines that have good transmissions, and there are more new agitator shafts here in the states than will ever be used.
We have saved a lot of transmissions out of machines we junked, As long as they were made after 1964 when they beefed up the gears, etc., and they didn’t have water in them. You never really see a serious problem with them.
The blue aftermarket pumps showed up around the time Whirlpool stopped making them maybe 15 years ago, I wouldn’t worry about it just get a genuine one to have on hand at some point the pump may work fine till then, a water pump is not gonna bring the machine down.
John
John
