Changing my GE's Transmission - Question...
geextrarinse
Jun 2, 2004
533
Hudson Valley, New York
Ok guys - how the hell do I get this cover off of these older models - there is no release tab - what's the secret? I obviously can't get very far until this baby comes off... Please advise!
Thanks!
Matthew
Matt,
I wouldn't worry too much about breaking it off if that's the only way. You can get new ones that are much easier to get on and off. The only way I was able to remove mine without breaking was to take two large flathead screwdrivers, slide them in on either side where those two "flaps" are, then of course wedge those flaps outward away from the agitator post while lifting upwards. Eventually you'll see how it works. The two flaps just snap on and lock.
Once you get that thing out of there only 3 large bolts hold the tub to the tranny. You'll need a pretty good size rachet to get those off. Get that tub off of there and you'll be looking at the boot and the two rings that hold it in place. I used a hexnut screwdriver on those to get them loose and release the boot.
Back to the rachet to remove the 6 nuts holding the transmission to the suspension below the outer tub. Once those are out you can lift it out and it'll be nice and heavy. That's the beauty of a GE tranny. It is all one piece that is easily replaced from the top. This would be a good time to really clean the outer tub, maybe a new belt, and whatever else you might need to do inside.
The hardest part will be getting that boot just right so it seals again. Also be very careful of any debris around the boot. I got a nasty stick from a rusty needle once.
If you need anything just let me know!
Jon
These are a b*tch!
You can try prying it off by inserting a flat-head screwdriver between the plastic cuff and that "notch" you can see in your picture and pushing the plastic outward. Since these are very replaceable, don't be afraid to use a lot of force.This old Lexan is very hard to break; it's just soft enough to be impossible.It is very difficult and very frustrating but I've removed two of these and have concluded that GE technicians used to have a special tool to do this.
I LOVE my GE!!!
Well, I managed to carefully get the plastic cover off with out breaking it with a screwdriver and a pair of long nose pliers, the bolts came out with a little bit of elbow grease and the tub needed a good yank (don't we all...) but I got the tranny out and the outer tub looks great! There is only a slight rust spot from where the larger clamp screw was by the drain hole. I'm thinking of putting that POR stuff in there - how does one do this - do i need to sand the rust off first? - do they have it at home Depot? It's amazingly clean inside the machine - I can't believe that for 40 years old - its almost immaculate! I'll post some pics...
Thanks for all your help and suggestions guys!
and by the way - the tub is actually Turquoise - and these I understand to be rare as well.
Matt
another pic...
drain hole rust... - there is really only one questionable spot where i can feel its rusting through to the other side... the rest i can just wipe off. This is where I wanna patch. It is not leaking yet, but i don't want to have to take it apart again anytime soon...
old tranny
how hard is it to rebuild these? - the only issue was that it indexed and the upper seal was starting to leak... Anyone ever done this? how hard is it? Everything else about these machines is so easy - are the transmissions the same? I'm not throwing this out.
Houston, we have a problem...
Ok, i can't seem to knock the old Spline out of the original agitator - what can i do - without changing the spline, i'm screwed because this won't fit the new transmission...
Matt,
Mine was very difficult as well. It will take some force but you'll get it. I think I used a larger rachet fitting and a rubber mallet. I placed the agitator on a towel for padding and protect from the floor. Made sure it was very flat and level. Then I pounded that sucker out with the mallet. It's the only way to get it out as far as I know. Just use your judgement and common sense as to how much is too much force so you don't break anything.
Jon
