Cinci to Akron Ohio Norge
akronman
Jul 20, 2010
2,258
Akron/Cleveland Ohio
It works! It's also dirtier than hell inside the outer tub.
Volvoguy got the machine wth a spare motor, knowing the original was either shot or nearly so. I let it sit in the basement about 9 hours at 65 degrees to warm up, all the pulleys and belts turned nicely, so I put it in spin and it tried weakly for about 10 seconds then tripped the 15 amp breaker. So, a half hour later I had the newer motor in, and she spun up to speed very quickly. I did some quick re-assembly and about a half fill of hot water, but she wouldn't stop filling! I jumpered past the fill pressure sensor, and this old Norge started BURPING!!!! I haven't had time yet to thoroughly check the pressure switch, but that will be an easy thing to figure exactly what's bad and replace it. But, this machine also does that neutral drain until the level drops and calls for water, then it kicks into both spray rinse and spin, so I had to stop it once it neutral drained to about 1/3, then I rewired so it called for water, and it spray/spun very nicely.
Here are some pics, she'll need an interior paint job for sure, but no current leaks anywhere, tub is good, bearings, etc, so maybe just TONS of cleaning, a new pressure valve, and she'll be fine.
My "Date your Appliance" link doesn't like this serial number. The lid says PN#33-79xx, the schematic on front of the tub says 33-78xx, and the name on the dashboard says 50th anniversary Norge(Should be 1976??). Anyone know the age?
[this post was last edited: 1/17/2012-00:33]
Tub dirt
sick stuff.
I did a hot wash with tons of soaps, and GENTLY shoved a rag around between the top of the inner and outer tubs with a screwdriver, got up loads of gross sick goop. Somewhere below is alos a picture of the tub cover, coated with dried slime.
Norge console
No "cool down " cycles, thank God. I haven't checked exactly what the soak and prewash do, should be pretty straightforward. This is my only machine with all that variety of speeds, and all 5 Hot/Cold/Warm choices, pretty cool.
[this post was last edited: 1/17/2012-00:34]
Norge Noise
Not only does that fun BURP make noise, and the brake solenoid, even the fill flume is damn loud on warm, with all that water pressure. I left one medium load of clothes in while testing for about 6 fills/washes/spins, so I don't have tons of Norge experience yet, but I am extremely impressed with the action of that relatively thin agitator, damn good turnover and force. This is my only 3/4 horsepower machine. Is that one reason, with others, for the noise?
tub cover
With that partial neutral drain, enough spinning water must get up to the top of this cover, then it has a screen and drips mostly bac into the tub, but excess will run down an overflow tube to the floor. Picture is of the tub cover upside down on the floor
here's more
Thanks again to Dave Volvoguy, this machine was well worth the trip. I'll let it rest a few days then figure out the pressure/level switch, that should be easy. Once it's up and running well for a week or so, I'll disassemble enough to paint the baseplate and interior entirely.
Questions for Norge experts so far:
LWA2065B00-----what parts online sites have diagrams for this? What age is it?
Flume---I think it's pretty cool that it does the neutral drain until the level drops enough to call for water, then it does the spin/spray/extract. Also, the timer says EXT. I've always seen SPIN or RINSE, never EXTRACT, pretty cool. However, with the flume spraying straight down, frankly not the exactly greatest spray rinse, huh?
Lint filter--more pics soon, but mine is cracked/near death. Any idea where to get a new one? I have an excellent fabric softener dispenser, pics soon.
No tub leaks, no seal leak, no bearing leaks, so it looks like a pretty standard de-rust/primer the interior, and get a new pressure valve, and she'll be BURPING.
Glad it's better than I thought.
Glad the motor fits properly, glad it's in better machanical shape than I imagined, and glad it looks to be an easier project than anticipated.
A Norge would have been fun for me, but I'm glad you have it and are enjoying it to the fullest extent.
Can you repair the old filter with shapable 2-part epoxy? It would take a lot of filing and sanding the hardened epoxy to get it to the correct shape, especially the drive key, but it couuld work.
With much pride and a little seller's remorse :)
Dave
Mark!
Congats on finally finding one of these! I hope you post plenty of pictures and have fun! I'm going to have to find one of these, I think I have a lead on an avocado Wards 18 lb machine, but nothing's in the bag yet.
-Tim
Mark Congrats on that Norge !!!
In my life I seen and used 7 of them.
In the style you have.
Great Washer !
The low vanes on that agitator I think and the long slopping base creates a very forceful wave like no other low straight vane System.
Good luck on the repairs and health of the washer.
Very nice to see you guys exchanged for good vibrations!
That's the beauty of A.W.
Darren k.
1965 WARDS SIGNATURE ELECTRIC DRYER
I have a white Wards dryer that works and needs a home contact me before Saturday or I will strip out the motor and scrap the rest. This is among the last of the good machines, or if anyone needs any parts let me know as maybe this machine can at least save the like of another.
Norge work
Supposedly we're getting snowed in tonight and friends cancelled plans, so I think tonight will be the start of de-rust--primer-paint on the Norge.
Ebay seller listed a lint filter as Magic Chef, but it's pure Norge-built and arrived today, now I have the complete machine and it's attachments, and last night I ran about 5 loads of clothes. It turned out the water level switch just required some good lung power to clean that 3 foot tube, now perfectly working again.  I'm loving this machine, a real workhorse, it wonderfully and reliably turned over major loads, the rinsing is medium with the spout aimed at only 1/2 the clothes, but no worse than my whirlpool. And while the fill spout is loud, the solenoid is loud, and the spin is loud, it's also entirely stable and solid. I always have to "fine-tune" the 4 legs of various machines on my ancinet basement floor, but this one just happens to be solid as hell, even during fast spin and fully loaded, damn fine machine.
But a question or two as I disassemble:  The picture shows the tub leans slightly rear and right. I've been down inside for other work so far, all 4 springs look fine, I'm guessing that i I label each spring before dismemberment, replace in same spot, then about 4 turns of the tightening bolt on the left front spring should do the trick? Even during high-speed spin and a full load, it tilts but is solid and stable as hell, fine spinning.
more
No water leaks from the tub, no oil leaks of any amount to worry me, so I'm leaving the entire drive and suspension together as I clean and paint the base. Is there any spot or two in the bearings or clutch or brake that I should lube or oil before re-assembly? It's Norge loud, but runs very well for agitate and spin.
The pic shows decent rust, but it's evenly spread around and no sign of one exact water leak, just generic 30 year old machine from a basement wear and tear.
