iheartmaytag
<span style="font-size: small;"> </span>
<span style="font-size: medium;">Hi, My name is IheartMaytag, and this is my story.</span>
<span style="font-size: medium;"> </span>
<span style="font-size: medium;">I didn’t start out my life thinking I would be phosphate dependent.<span style="mso-spacerun: yes;"> </span>I just took it for granted they would always be there.<span style="mso-spacerun: yes;"> </span>When the manufactures took phosphates out of laundry detergent, I was able to survive.<span style="mso-spacerun: yes;"> </span>It wasn’t until automatic dishwashing detergent had it’s phosphates removed that I started to wonder what it would be like to experiment with phosphates. </span>
<span style="font-size: medium;">Sodium tripolyphosphate<span style="mso-spacerun: yes;"> </span>(STTP) or <span style="mso-ansi-language: EN;" lang="EN">Na<sub>5</sub>P<sub>3</sub>O<sub>10<span style="mso-spacerun: yes;"> </span></sub></span>as the chemist like to call it is an inorganic compound of sodium salt and polyphosphate which is conjugated with a base of triphosphoric acid. <span style="mso-spacerun: yes;"> </span>STTP is highly water-soluble, non-toxic, approximately two million tons of STTP are produced per year.<span style="mso-spacerun: yes;"> </span>Much is/was consumed as builders for detergents, Other uses are preservatives for fish, poultry, and baked goods.<span style="mso-spacerun: yes;"> </span>STTP also finds it’s way into leather tanning, ceramics, flame retardants and antifreeze. </span>
<span style="font-size: medium;">The biggest negative the Environmental Protection Agency had against STTP was the eutrophication of many fresh waterways that if found it’s way into via waste disposal and run off.<span style="mso-spacerun: yes;"> </span>Beings as phosphorus can generate it’s weight 500 times in algae the risk to waterways prompted the ban of this additive in many areas. <span style="mso-spacerun: yes;"> </span>http://en.wikipedia.org/wiki/Sodium_triphosphate</span>
<span style="font-size: medium;">With this knowledge I was determined to tough it with the rest of the country and use my phosphate free detergent, but I couldn't. My first step to the addiction was I began hoarding packages of Cascade Complete 8% phosphate before the ban.<span style="mso-spacerun: yes;"> </span>I bought as many bags as I could afford everytime I went to the store.<span style="mso-spacerun: yes;"> </span>Then suddenly, it was gone.<span style="mso-spacerun: yes;"> </span>The light green packages appeared on the shelves. </span>
<span style="font-size: medium;">Hearing complaints from others, I was worried, but with every load I washed, I would say this is just until they get a new formula that worked as well as phosphates. Then I would asked myself.<span style="mso-spacerun: yes;"> </span>Is this load dirty enough, does it warrant the use of my “good stuff”?<span style="mso-spacerun: yes;"> </span>So I bought my first package of Cascade Complete phosphate free.<span style="mso-spacerun: yes;"> </span>At first I though the results were pretty good, good enough not to use anything from my stash, then I began noticing that even with Jet Dry there seemed to be<span style="mso-spacerun: yes;"> </span>a white film on the dishes when I took them out of the dishwasher. <span style="mso-spacerun: yes;"> </span>“It must have just been that load” I said to myself. I will use the good stuff in the next load.<span style="mso-spacerun: yes;"> </span>But when the next load was ready, I couldn’t bear to get into my stash.<span style="mso-spacerun: yes;"> </span>What If I had a really dirty load?<span style="mso-spacerun: yes;"> </span>I can’t waste it.<span style="mso-spacerun: yes;"> </span></span>
<span style="font-size: medium;">Like so many others in the group I was headed down the path of addiction, but still didn’t realize it. I began product switching. I knew I could quit phosphates anytime I wanted to, I just didn’t want to.<span style="mso-spacerun: yes;"> </span><span style="mso-spacerun: yes;"> </span>I read Automaticwasher.org everyday and many people were saying good things about Finish so I bought a trial box.<span style="mso-spacerun: yes;"> </span>Like Cascade before it, at first I thought I had good results.<span style="mso-spacerun: yes;"> </span>So I bought a second box, and again thought the results were pretty good, but I was noticing the tell-tale white powder on the dishes.<span style="mso-spacerun: yes;"> </span>Still I bought the third box, it was then that I noticed the white scale was starting to build on the heating element, as well as there were brown stain/streaks appearing on the dishwasher interior.<span style="mso-spacerun: yes;"> </span></span>
<span style="font-size: medium;">What should I do?<span style="mso-spacerun: yes;"> </span>If I continued to use my stash I would be completely out in about three months.<span style="mso-spacerun: yes;"> </span>I tried washing every other load with the good stuff, and continued to use the Finish powerball in between.<span style="mso-spacerun: yes;"> </span>I considered Glass Magic, at 22% phosphate it would do the job, but $3.65 for a 12oz box, this just would not do. </span>
<span style="font-size: medium;">Finally like so many addicts have done, I began phosphate seeking behaviors, searching for a phosphate fix, a supplier that wouldn’t run out on me, <span style="mso-spacerun: yes;"> </span>a dealer that would be economical, keep me happy, but serve my needs when I had them, best of all a supplier that would be there for me always.<span style="mso-spacerun: yes;"> </span>I found the Chemistry store on Google, and ordered an 11 lb tub of STTP and had it shipped.<span style="mso-spacerun: yes;"> </span></span>
<span style="font-size: medium;">My fist fix, was pure euphoria. I added just 1 TBSP of STTP with the Finish capsule and ran a soiled load with a baked bean crusted casserole on the Autoclean cycle. <span style="mso-spacerun: yes;"> </span><span style="mso-spacerun: yes;"> </span>To my amazement when I opened the door, the dishes sparkled, and the brown stains were gone, not faded, gone from the interior.<span style="mso-spacerun: yes;"> </span>Everything was clean including the heating element.<span style="mso-spacerun: yes;"> </span>I was hooked, I bought a sugar dispenser and filled it with STTP and marking it with a black Sharpie. I kept it right next to the detergent above the dishwasher.<span style="mso-spacerun: yes;"> </span></span>
<span style="font-size: medium;">Next I thought, I have this big tub of STTP, why not try it in the laundry. I was amazed again, the Whites sparkled, the towels felt softer, and the rinse water was clear.<span style="mso-spacerun: yes;"> </span>I placed a small container in the pedestal so it would be handy and sealed my tub for future use. </span>
<span style="font-size: medium;">Now the greatest issued with my addiction—I don’t want to quit.<span style="mso-spacerun: yes;"> </span>I said I could quit when I wanted to, but I can’t.<span style="mso-spacerun: yes;"> </span>I could buy a water softener, but the $27.17 tub of STTP is much more economical.<span style="mso-spacerun: yes;"> </span>I rationalize that the salt from a softener is harmful to the waterways as well, and I would be releasing 25lbs or more a month with that method. <span style="mso-spacerun: yes;"> </span>For now all I can confess is—I am a Phosphate addict. </span>
[this post was last edited: 7/28/2011-12:00]
