Remember the vast predominance of Internet reviews will ALWAYS skew negative on any product. People that are truly pleased with any given item seldom ever take to the Interwebs to bother to write glowing reviews. On the flip side if people are unhappy with a product (even if they are the cause) they will write a negative review where ever they can! While doing research via reading the forums on the Internet is a good thing, you must be very careful with how you interpret the data. You can't be sure what the sample really is. Analysis based on flawed data is ultimately flawed.
Indeed there is a class action suit due to the "stinky washer" syndrome, and very likely they will prevail over the manufacturers. In this litigious society that we now live in the courts often side with people that don't have common sense. Get burned by hot coffee and get a check...
The people that pay attention to their laundry and are able to adjust their habits to properly use a front load machine don't have any stinky washer problems. I have known people to develop stinky top loaders too, its NOT the machine.
Your opening message stated that "NO WAY IN HELL" would you get a front load machine so clearly your decision was already made. The SQ top load machine is indeed the best modern version of a traditional top load machine. You are likely to be pleased with it in the long run. But there are distinct advantages to a front loading machine which you just can't get with a top load machine. Coloring front load machines as being bad due to others improper usage is a shame. Most all of Europe and almost all commercial laundry can't be wrong.
