Convection element
Range in post #22
ALL four top burners have thermostats built into the surface elements, ALL cast-iron elements like this have two elements and a thermostat that cycles one element off to keep the surface temperature around a maximum of 850F when using the element on high heat.
The only CI elements that do not have this built-in thermostat are ones that have an exposed thermostat that is spring loaded and contacts the bottom of the cooking vessel.
Thermostats are a very necessary part of any well performing and safe range.
John L.
"Thermostats are a very necessary part of any well performing and safe range."
Well, that is contradicted by the millions of Calrod units that have zero thermostatic control with the infinite switch set to high virtually eliminating any cycling.
Yes I know UL just recently required that Calrods have a T-stat, but that is from careless inviduals who IMO should not be cooking to begin with. Anytime your oil or fat smokes you are way off, and ingesting something that is toxic if you ask me.
These burners don't cycle on and off and they have only one element. The knobs of these burnes most of the time have 7 positions: . 1 . 2 . 3 and 0. There is no safety feature, no automatic shut off when temperatures get too high. Here is a new Smeg cooktop (or hob as it is called in British English).
https://www.vandenborre.be/elektris...ductiekookplaat/smeg-se-435-s?type=attributes
Here is a translation of a part of the product sheet:
Reply #37
Hi Louis, I say they do have over heat protection thermostats in each element.
Glass top cooking elements also all have thermostats built into the elements to keep maximum glass surface temps around 1000 F.
These built-in thermostats in CI elements are a major reason why Europe used so many CI elements as they are safer and this is required in much if not all of Europe.
John L.
Thermal Limiters On CI Sealed Elements
I am not going to get into pissing contest but to not have a TL the element would have to be very low wattage probably less than 600 watts.
Everyone I have ever seen sold here in the US has one built-in, and I find it hard to believe that our safety standards are that much tougher here.
It is easy to confirm the presence of these BILs, just power up the element on the highest heat and take a amp draw reading and in 10 to 20 minutes you will see the amp draw drop to approximately 1/2.
These limiters are built-in to the element assembly and are not serviceable and often do not even show up on wiring diagrams, but they have to be there to prevent damage to the range top or the element itself.
John L.
Not interested in a pissing contest, but it is definitely in the German text in the link. And that is mainly based on German appliances, back then there were a lot of national companies, not working to certain standards. The high power burners mentioned in the German thread were introduced here in the mid sixties, at the same time "sensi-temp" burners were introduced, something you had much earlier.
The European market was quite different back then. In the past we established that a small country like the Netherlands (just over 10 million people) had many appliance manufacturers (I forgot how many washing machine factories there were in the mid 50's, but it might have been something like 70 or so) Just compare it to NYC having 60 washing machine factories. Safety standards were probably not as good as in the USA back then. The European Union has done a lot in that matter. Every country had it's own manufacturers and also had their own safety standards (which weren't that good). Even until today there are some Dutch manufacturers that still only make products for the Dutch market.
Interesting Stove Designs Reply #49
Yes indeed Louis, the number of interesting designs that were out there years ago would fill a book.
My first real experiences with Solid Cast Iron elements were in the 80s when these European elements made a brief splash here so all my comments only apply to the 80s on.
Because all the CIEs sold in the US were temperature limited they could mount them directly in porcelain or even tempered glass cook-tops without fear of damage or breakage.
John L.
Whirlpool-
My mistake. Bad reference to post #42.
Whirlpool has several flat cooktops and ranges where the 1,100 watt element does not go through the limiting thermostat.
I was wondering why that is. But hey, thanks for the inspiration Whirlpool ;)
All this stuff!
Is too complicated I will keep my 59 Westinghouse I can bake on any rack, load the oven full and still have even browning , No convection needed I don't NEED new technology to be able to cook.
