Cook-O-Rama! Part Two
Ultramatic
Sep 28, 2011
42,387
New York City
Formally Recipes: Old and New.  An update of one of my earliest threads. Recipes from vintage cookbooks, food product recipe pamphlets and magazines. While the emphasis is on vintage, new recipes are welcomed also. When available, I will post the name of the publication and year published with the recipe. Food product advertisements containing recipes will continue to be posted in the Vintage Food Advertisements series. As usual, I will start a new part when posts hit 100.
Get ready, get set, EAT!
http://www.automaticwasher.org/cgi-bin/TD/TD-VIEWTHREAD.cgi?36927
In response to a post in part 1: quark, tvorog/творог, syr — all of these are fairly common in Atlanta.  I would think that cottage cheese would not quite fit the bill; it certainly isn’t very sour, and it has curds that are much like actual cheese.
I love tvorog on a bagel, just like cream cheese.  I always sprinkle it with coarse salt.  SO GOOD!
<header class="post-header title-container fix">
<h1 class="posttitle"><span style="font-size: 24pt;">Maultaschen Swabian Pockets Recipe</span></h1>
</header>
Do you know the authentic Maultaschen Swabian Pockets Recipe?  This local food specialty from the South of Germany, Swabia, are filled pockets or ravioli with meat and/or vegetable.
The classic filling is a mix of spinach and ground beef. Some recipes are using bratwurst filling, and some are without meat. There are different ways how to serve them. They taste delicious in a beef broth or fried in the pan with roasted onions or bread crumbs. Home made Maultaschen requires some cooking skills and time. You would need a ravioli cutter and a wide enough wooden board - In Germany you use special baking boards that can be easily  adjusted at the table's edge so they won't move around. Happy Cooking!
<h2>Ingredients Maultaschen Swabian Pockets Recipe </h2>
Dough
350 g flour
1/2 tsp salt
3-4 eggs
1 tbsp vinegar
For the Filling:
150 g fresh or 100g frozen spinach
1 onion
1 1/2  German bun (some days old, not fresh)
200 ml warm milk
200 g ground pork or beef
2 tbsp parsley (chopped)
2 eggs, salt, pepper, nutmeg
1.5 l beef broth or water
fresh ground nutmeg and pepper
<h2>Cooking Instructions Maultaschen Swabian Pockets Recipe</h2>
- Beat eggs, 3 tbsp water, vinegar with a whisk and add bit by bit the flour; knead it then until you get a firm, smooth dough.
- Cover dough or wrap it it in foil and let rest for 30 minutes.
- Fresh spinach: Wash thoroughly, remove hard parts like stems and roots. Defrost frozen spinach.
For the Filling
- Soak roll in milk and squeeze all milk out. Bun should not have any liquid in it.
- Peel onions and chop it finely.
- Melt butter in a skillet; add onions, chopped parsley, spinach and bun; saute for some minutes
- Add ground beef, spice with salt, pepper and nutmeg, mix well, then take off  and let cool off a bit.
- Now roll the dough (on a wooden board with some flour) and with a special roller make 15cmx15cm (6inches x6inches) squares. Dough should not be thicker than 3mm (1/4 inch).
- Brush water or egg white on the edges.
- Place 1-2 tbsp of the filling on each square.
- Fold the squares to a triangle and press the edges firmly together. Now cook them either in water or broth.
- Bring water with some salt  (or the broth) to a boil and place pockets inside, they are done when they float on the surface.
- Remove them from water by using a slotted spoon.
- Melt butter in a skillet and roast them on both sides slightly, in a separate pan roast bread crumbs.
- Sprinkle Maultaschen with parsley and the breadcrumbs.
Servings Options
- With roasted onion rings,
- fried in butter.
- with roasted breadcrumbs,
- brown gravy,
- in a broth,
- with potato salad or fried potatoes. Never forget to sprinkle with parsley.
Don't laugh at this one....
Here's a recipe that was invented by my Great-grandmother and probably came about as a result of the Depression.  She called it Scalloped Eggs and it has been a Christmas dinner tradition ever since.  If you like eggs and cheese you will like this.  There are really no measurements because it's a taper as you like recipe.  If you have high cholesterol you might want to refrain...
6 boiled eggs (may use more if a large dish is used)
1 small block of cheese (we always use Velveeta, size depending on how much cheese you like)
Butter or margarine
Saltine crackers
Milk
Slice boiled eggs.  In a deep casserole dish place a layer of saltine crackers on the bottom, followed by a layer of egg slices, then a few slices of velveeta (I make my slices about 1/4 inch thick), and some chunks of butter or margarine.  Repeat beginning with saltines again and continue until the casserole dish is filled with layers.  Top with more cheese and butter.  Heat some milk (amount depends on size of dish) in a pan or the microwave to hot but not boiling and pour over cracker/egg/cheese layers...you want enough milk to soak the dish and it WILL absorb (I like them soupy myself) and then place on a cookie sheet (it will bubble over) and bake in the oven at 350 until bubbly and hot in the middle...approximately 30 minutes+/-.  If it's too dry can always add a little more milk.  These are even better the next day as leftovers in my opinion, but you will have to add a little more milk before reheating them because it will continue to absorb.
What a fascinating cookbook that will be!  I already want to try that sandwich spread!  Have you ever seen the recipe for heating cocktail weenies in a crock pot with grape jelly?  Grapes and pork-product must have been a popular combination at one time.
The spelling of the word ‘tvaroh’ is really interesting.  It ought to end in ‘g’, but kids and grandkids who heard the word—but didn’t know the language—probably didn’t realize the ‘g’ was there.
It reminds me of a recipe I saw in a church cookbook that called for ‘arsh’ potatoes.  That would be ‘Irish’ potatoes (white potatoes), as opposed to ‘sweet potatoes’.  The recipe must have come from a kid or grandkid who wrote down what grandma said, but didn’t know enough about that wonderful Appalachian accent to understand the word.  I’ve also seen and read ‘anisy’ when ‘anise seed’ was intended.  I’ve seen several other funny spellings, but these are the only two that come to mind right now.
It will be an interesting book. There are plenty of modern recipes.
But there are some canning recipes from farm folks, and some old-fashioned recipes such as Mothers Oats Cake and Farina Dumplings.
And of course some nice ethnic recipes like pierogi, prune filling, Hungarian pancakes, Kiffle dough etc.
Here are some vintage recipes from the last Cookbook our parish published. The front cover and the local businesses that sponsored the book show its age.
I make the Pineapple Skillet Sponge recipe often, and have swapped peaches in place of pineapple too.
The Farmers Almanac Cookbook 1964
<strong class="cbl" style="color: black;">FARMERS' ALMANAC HAM LOAF</strong>
2 cups ground cooked ham
1/2 cup nonfat dry milk powder
2 teaspoons Worcestershire sauce
1 egg, slightly beaten
2 cups cooked, mashed sweet potatoes
1/4 cup brown sugar, firmly packed
2 slices canned pineapple, drained
Combine ham, dry milk, Worcestershire, egg and sweet potatoes; mix well.
Sprinkle brown sugar evenly on bottom of well greased 8- to 9-inch loaf pan.
Cut pineapple slices in half and place on top of sugar. With spoon, spread ham mixture over pineapple.
Bake in 350 degree F oven until loaf is slightly browned and firm, about 25 minutes. Serve at once.
Wheat Flour Institute 1956
<strong class="cbl" style="color: black;">REUBEN SANDWICH</strong>
18 slices Russian rye bread
1 1/4 cups Thousand Island Dressing
12 slices Swiss cheese (about 12 oz)
1/2 cup sauerkraut
24 slices corned beef (about 12 oz)
Butter or margarine
French fries (for serving)
Spread 12 slices of bread with dressing. On each of 12 bread slices, arrange 1 cheese slice, 2 teaspoons sauerkraut, and 2 slices corned beef.
Double-stack these bread slices to make six sandwiches. Cover with remaining 6 bread slices. Secure with toothpicks.
Spread outside surfaces with butter or margarine and grill until cheese is melted and sandwich is heated through.
Cut diagonally into three pieces. Serve with French fries as a garnish.
Makes 6 sandwiches
Standard Osterizer Recipes 1957
POPOVERS
1 cup milk
2 eggs
1/4 teaspoon salt
1 cup sifted all-purpose flour
Put the milk, eggs and salt in the blender container. Cover and mix at Hi Speed until bubbly. Add the flour and run at Hi Speed until perfectly smooth.
Fill well-greased muffin pans, custard cups or popover pans half full.
Bake at 450 degrees F for 30 minutes. Reduce heat to 350 degrees F and continue baking 10 to 15 minutes longer.
Makes 8 popovers
Source: Standard Osterizer Recipes, Oster Blender Model 432 Manual, 1957
<hr />CHEESE POPOVERS
1 cup milk
2 eggs
3/4 cup cubed sharp American cheese
1/2 teaspoon salt (or 1/4 teaspoon as in above recipe)
Butter (for serving)
Put the milk, eggs, cheese and salt in the blender container. Cover and run at Hi Speed until cheese is finely grated and the mixture is bubbly, Add the flour and mix at Hi Speed until thoroughly blended.
Fill well-greased muffin pans half full.
Bake at 450 degrees F for 20 minutes. Lower the temperature to 350 degrees F and continue baking 15 minutes longer.
Serve hot with butter.
Salt Lake City Deseret News 1948
<strong class="cbl" style="color: black;">OLD FASHIONED POUND CAKE</strong>
1/2 pound butter, creamed
1 3/4 cups sugar
5 whole eggs
2 cups flour, measured after sifting twice
nutmeg or mace to taste
Beat like the devil, 1/2 pound butter, (more if you have it). Add 1 3/4 cups sugar with the creamed butter. Cream until fluffy and light. Then
drop in 1 whole egg at a time and stir slowly until you have dropped in a total of 5 eggs. Then fold in 2 cups of flour that has been measured after it has been sifted twice. Do not beat as that makes it tough.
Flavor with a little nutmeg or mace.
Cook in a loaf pan about 45 minutes at 300 degrees F. Turn oven up to 325F. for browning. Leave it at 325F. for 15 minutes or until a nice golden brown."
The Milwaukee Sentinel 1948
<strong class="cbl" style="color: black;">SOUR CREAM RAISIN PIE</strong>
1/2 cup raisins
1/2 cup nut meats
1 cup white granulated sugar
2 1/2 tbsp flour
1 tsp cinnamon
1/2 tsp ground cloves
1 1/2 cups sour cream
3 egg yolks
1 (10 inch) single pastry pie crust, baked
3 egg whites
6 tbsp white granulated sugar
<strong class="cbl" style="color: black;">TO MAKE THE FILLING FOR A 10-INCH BAKED PASTRY PIE SHELL: </strong>
Mix together and chop raisins and nuts.
Then mix together the dry ingredients; (sugar, flour, cinnamon and ground cloves), and add to chopped raisins and nuts.
Pour sour cream over above mixture and stir all together thoroughly. Place in double boiler and bring to at boil.
Beat 3 egg yolks in a cup, add some of hot mixture to egg yolks, mix well and stir egg yolk mixture back into pan. Stir mixture in pan constantly to avoid lumping. Continue cooking until thick.
Pour thickened mixture into a baked pastry shell.
In a separate bowl, beat the egg whites, adding a total of 6 tbsp sugar, gradually, until egg whites stand in a peak.
Top pie with this meringue and bake in a 350 degree F oven until meringue is golden brown, about 20 minutes.
All Electric-Mix Recipes (Dormeyer) 1946
<strong class="cbl" style="color: black;">ESCALLOPED CORN</strong>
1 tbsp. butter
2 tbsp. flour
1 cup milk
2 cups corn (whole kernel)
1 1/4 tsp. salt (or to taste)
1 tsp. sugar
Dash ground black pepper
2 eggs
1/4 cup diced ham
1/2 cup diced American cheese
Melt butter in a saucepan. Add flour and mix well. Add milk and cook until it comes to a boil, stir constantly, cook 2 minutes longer. Add corn, seasonings, ham and cheese; set aside.
Beat egg yolks 1 minute at medium speed; set aside.
In a separate bowl, beat egg whites 2 minutes until stiff, use high speed. Fold egg yolks and whites together, then fold into corn mixture. Place in a buttered baking dish.
Bake 30 minutes at 350 degrees F.
Makes 5 or 6 servings
French Onion Soup Pork Chops
<span class="ERSPrintBtnSpan"><span class="ui-button-text"> </span></span>
Prep time
<time datetime="PT20M">20 mins</time>
Cook time
<time datetime="PT30M">30 mins</time>
Total time
<time datetime="PT50M">50 mins</time>
Serves: 4
Ingredients
<ul>
<li class="ingredient">4 boneless center-cut pork chops, about 1-inch thick</li>
<li class="ingredient">1 tbs olive oil</li>
<li class="ingredient">1 cup caramelized onions</li>
<li class="ingredient">¾ cup beef stock</li>
<li class="ingredient">¼ cup dry white wine (see NOTES)</li>
<li class="ingredient">4 tsp whole-grain dijon mustard -OR- regular dijon mustard</li>
<li class="ingredient">4 slices sharp provolone cheese</li>
<li class="ingredient">1-2 sprigs fresh thyme -OR- ⅛ tsp dried (see NOTES)</li>
<li class="ingredient">½ tsp salt (optional)</li>
<li class="ingredient">¼ tsp pepper</li>
</ul>
Instructions
<ol>
<li class="instruction">Preheat oven to 350 degrees F.</li>
<li class="instruction">Heat a large oven-proof skillet over medium-high heat. Add oil.</li>
<li class="instruction">Sprinkle pork chops with pepper and salt if using.</li>
<li class="instruction">Brown chops on both sides in hot skillet. Remove pork chops and set aside.</li>
<li class="instruction">Add the stock, thyme (if using) and wine to the pan and deglaze (that's scraping up all the browned bits so they dissolve in the liquid).Add the caramelized onions. Cook for about 3-5 minutes until liquid is slightly reduced.</li>
<li class="instruction">Spread 1 tsp of the mustard on top of each chop. Place chops in skillet with the onion/stock mixture.</li>
<li class="instruction">Place the pan in the preheated oven and cook for 20-25 minutes, or until chops register 160 degrees F on an instant-read thermometer.</li>
<li class="instruction">Place slice of cheese on top of each chop--I find folding the cheese in half works best and creates a double layer of cheese.</li>
<li class="instruction">Place the skillet back in the oven and cook for about 5 minutes, or until cheese is melted and just begins to brown.</li>
</ol>
Notes
If you used thyme in the recipe for the caramelized onions, it can be omitted in pork chop recipe.
The white wine can be substituted with an equal quantity of beef stock
SLOW COOKER DIRECTIONS--Follow the recipe for caramelized onions bearing in mind they take about 10 hours so plan accordingly if you plan to make this meal along with the onions. If you do, at the end of the 10 hour cooking time, add the browned chops with the mustard spread on each as in the main recipe, and the stock and wine. Cook for an additional 5-6 hours. You can melt the cheese over the chops either in the microwave or regular oven.
I feel it's better to make the onions on one day and make the pork chops on another day. To do it that way, add the caramelized onions to the crock pot along with the stock and wine. Brown the pork chops, spread the mustard over them and place them in the slow cooker. Cook for about 5-7 hours on low, 4-6 on high, but check for doneness at the MINIMUM times. If you are using a casserole crock and you have the pork chops in a single layer, at the end of the cook time, place the cheese on top of the chops, cover and let the cheese melt. If you had to pile the chops in the cooker, you will have to melt the cheese either in the oven or microwave.
