Allrightythen. Here's a video of the goofy thing refusing to spin. I'm hoping someone can tell me what's wrong. The machine is useless until this problem is fixed.
Notice how the clutch works. When the motor runs one direction, the basket brakes and the lifters (correct technical term for the tumble discs) rotate instead. Being as the load is pulled up the side of the basket, spin would be seriously off balance ... so when the motor reverses for spin, the lifters rotate a little in reverse to center the load. The clutch can fail such that the lifters keep turning continuously during spin, which obviously will cause chronic/continual off-balance. The clutch on this machine did fail in exactly that way when it was 6 months old, and was replaced under warranty. The machine wasn't used after that repair until a few months ago. The replacement clutch is working properly, but it refuses to spin, apparently for sensing the load as being off balance when IT IS NOT.
Not shown in the video is the tub displacement sensor at the left front, attached to the tub and to the edge of the cabinet. It looks like a support strut or shock, but is not. It has ball joints at both ends and moves freely with the tub to sense oscillations for OOB conditions. The original sensor passes all diagnostic tests, but I replaced it anyway, and that did not solve the problem.
Be advised the video is 37 mins long in real time and isn't very good quality. It begins during the 1st rinse, before which the 1st spin had already failed in the same way that you will see the 2nd spin fail (after the 1st rinse). Full cycle sequence is wash, spin w/spray, tumble rinse, spin w/spray, final tumble rinse, final spin (also with a spray at the start).
Neptune TL Spin Fail
