danemodsandy
I am just coming off a serious flooding of my laundry room and basement that happened last night; I was up till all hours with the carpet cleaner.
What seems to have happened is the washer drain standpipe backed up when the washer pumped out the wash water. Not only was there evidence of overflow around the standpipe, the laundry room sink (in a counter several feet away from the washer) also overflowed; there was sudsy water all over that counter.
This is not the first time this has happened, but it was definitely the most serious. The problem seems to have something to do with detergent. We cannot use powders (my preference) at all, because there'll be water all over the floor if we do. Using too much liquid will also trigger the problem; I think I got a little slap-happy with the measuring cap last night. Loads with sheets also seem to trigger the problem; the load I was running was sheets. I do not stuff my washer (an LA 108 centre-dial Maytag), and I stick to the measuring recommendations on the detergent label. Also, the problem seems to occur when I've used something besides my regular detergent, Huish's Sun liquid. Last night's epic flood seems to have come courtesy of the Arm & Hammer people.
I've got everything clean and dry now, and I've put some commercial drain cleaner in the drain, flushing for the full five minutes, just in case there was some kind of blockage. And the washer seems to be working okay now. But is there anything I can do to eliminate this problem, or to minimise it? I'm exhausted from tossing washers, dryers, and the other contents of the room around, to say nothing of mopping and running the carpet cleaning machine.
