Darn that Dominion
turquoisedude
Aug 8, 2007
10,562
OR "A Pox on Paul's Pumps"....
So last fall, I wanted to see how well a solid-tub washer would remove dog hair from Canyon's car blankets (retired folk...what can I say?)
The wash test at that time was a failure because the blasted Dominion washer wouldn't drain! I had theories about it, but did not get to tinker with it until last weekend...[this post was last edited: 12/5/2013-16:52]
When I took the pump cover off (CAREFULLY this time...LOL) I quickly saw that my clog theory could be discarded. I now feared I had a repeat of what happened to the Canadian Westy shortly after I got it up and running again.
Well, I was right... Like the Westinghouse, the pump impeller had detached from the drive shaft. So I picked up my local phone book and found the Dominion/Beatty parts and service department number - KL5-8736. When I called it they said the number was no longer in service, though...
Back to reality, I knew darn well that a replacement pump for this washer will be impossible to find. I thought a coat of JB Weld might solve the problem.
Well it did work... for about one wash cycle, though...
I'll try this approach again when I get back down to Ogden next weekend, but in the meantime, if anyone has any suggestions for a better way to re-attach the rubber impeller back to the drive shaft, please let me know!
It's not all doom and gloom, though...
While the Dominion was out for service, I finally got around to repairing the original water valve (thanks again, John, for the valve diaphragms!). I am thrilled to say that I now have the Hot and Warm options for washing and Warm and Cold options for rinsing again!! I still don't think I'm getting enough water into the tub, but I'll tinker with that when (notice I didn't say 'if'!) I get that pump back into service.
So, with two bad pumps now, I am almost afraid to use any of the other washers in the Ogden Laundry... LOL
Paul I had the exact same thing happen to my '52 Speed Queen earlier this year. I happened to have a new pump shaft kit, so I was able to replace just the impeller/shaft. Is the Beam pump on the Dominion the same size as a speed queen pump do you know?
Robert, I have a feeling that it may be as the SQ pump clamp Greg found for me was a perfect fit. I am a little reluctant to take the pump out and dismantle it, though! I'm still licking my wounds from the Inglis... LOL
Paul this is an extremely simply pump to take apart. You pretty much take the pulley off and the shaft should pull right out. Careful of the seals and be sure to note which way they go on the shaft.
I'd be curious to know what the shaft diameter is for Paul's Dominion. The '56 Hotpoint needs a new seal and I figured I could use a Speed Queen seal. Unfortunately the early pumps use a different diameter than the later SQ pumps (60's/70's). And, due to the mounting and pump height differences I can't replace the pump for an SQ one.
Someday I'll figure out a solution, but for now, the Hotpoint is a pretty decoration in the corner of the basement.
Ben
I often wish I had a machine that could inexpensively re-create any NLA part I that need just by entering the part number!
Or better, a machine that could re-create something I want just by typing the model number!
I'm working on that, but so far, it only recreates two-dimensional copies of the objects I want!
So, after the success with the Maytag, I thought I should take a look at the Dominion again. I popped the washer on it's back and opened up the pump chamber.
I was amazed to find that my JB Weld 'repair' to re-attach the impeller to the pump shaft actually HAD worked! It was nice and secure when I checked it.
And here's why it wasn't draining.... This bracket fell out of the pump chamber when I opened it! It must have been blocking the impeller - what it is and where it came from is a mystery, but I reassembled the pump and tried the machine again.
Here's the bad news: I can't seem to get the washer to spin anymore. It will agitate but when it attempts to engage a spin, nothing happens except for some very slight tub indexing...
Now this is going to be a challenge - I probably have less service and technical information on this machine than any of the others. I may just have to head back to the museum in Elora, Ontario where I found some Beatty/Dominion appliance information archived there!
I have some theories about the machine but I am open to all suggestions! My first impression is that perhaps the motor (already weak) is just not revving up to the right speed when it reverses to go into 'spin'... I'll have to take the cabinet off the machine to get a good look at the transmission, though. I'm just not sure when I'll get to that! There's a very sick Inglis in the basement repair ward and a replacement dry thermostat for a certain GE Combo that is begging to be installed, too!
Looks like 2014 will be a fun year for me... LOL
Exploratory surgery on the Dominion
Still feeling somewhat defeated by my lack of progress on the Inglis, I thought today might be a good day to inspect, observe, and try to figure out just why the heck the 58 Dominion decided to stop spinning after all the pump issues seemed to have been sorted out...
I'm really out on a limb here because I have zero in the way of service or technical information about this machine. But hey, I've jumped blindly into these things in the past right??
After the grief with the Inglis, I figured this is the problem: the belt.
One nice thing about this washer - you can take the belt off very easily!
The close-up is not good, but the 'shine' on the outer belt surface seems to confirm my theory. This is definitely a case where a smooth surface is not your friend!
Now, why would a slick outer surface on a belt be the cause of not spinning?
I wouldn't have thought so either until I sat down and carefully watched how the machine operates.
The drive belt links the motor (not shown) with the pump pulley, the transmission pulley and a central drive pulley. The belt is looped with the inside surface of the belt around the pump and transmission pulleys, but the outside surface of the belt contacts that central drive pulley. When the machine is agitating, the motor is running clockwise - the inner surface of the belt still had some 'pull' on it, so the machine had no trouble washing. But to spin, the motor reverses and drives that central pulley to make the tub spin. It takes some force to do this and my theory is that the smooth belt just doesn't grab enough to make the tub spin.
Anyway, it's my theory for the moment and I'll know for sure later this week when I try to find a new belt!
[this post was last edited: 2/2/2014-14:52]
Belt located! My source for belts, bolts, hex and unhexed screws, etc in Magog had the belt I need for the Dominion! Darn near ran out of gas after going there but that's a whole other story... So, I may just try to re-belt the Dominion tonight - keep your fingers crossed!!
Hear that 'bang'?
As in '...goes another one of my theories'!
Got the new belt in easily but the darned Dominion still won't spin. I had a lengthy discussion with Phil about this before I put the belt in (therefore it's HIS fault the machine won't spin...LOL) and he was asking me if there was some kind of a clutch or other mechanism that would also engage when the motor reversed for the spin. Well, that I don't know; what I do know is that if I'm going to find out, the cabinet will have to come off to be able to really see what other components might be used to make the washer spin.
Off I go into uncharted waters... WHEEEE! I'll post photos as I disassemble, I promise.
For tonight though, I'm going curl up next to Canyon and whimper ...
